Question about Element Electronics FLX-3211B 32 in. LCD HDTV
Lost panel light
Have power,sound,all inputs,and all outputs work can not get past metal cover to find bulb would it be cheaper to take it to someone live in roanoke va
  • 308 Answers
It is not 1 bulb but a series of long cold cathode bulbs with mercury vapor inside. If any one fails, they all go out. If the inverter fails, they all go out. Don't open the panel. Lamps can be tested in the panel by someone who knows how. Very high voltages also. Safer to take it to a shop.
Posted on Apr 27, 2010
What one is the live wire for the radio for
Its usually a red or black. You can buy an inexpensive tester to find a live circuit or make your own. Get and 12V bulb and 2 lengths of 16 or 18 gauge wire. Solder one wire to the center contact of the bulb, the other to the metal case of the bulb. Cover the case and exposed solder joints etc with electrical tape. Turn on the radio. Attach the case (ground wire) from the bulb to any metal in the car, use the other (positive end attached to the bulb) as a probe. Probe each plug going into the radio, when the bulb lights, you found a hot circuit.
Aug 10, 2014 | 2003 Ford Windstar
I have a peavey cs800 s that has no output on channel B. im hoping someone can tell me the first few things i can check. its not the input source or cables i do kniow that much. havent found any loose
Switch inputs, switch speakers, if not you need to open it up(unplugged from power) and do a visual inspection.. possible bad power/output transistor(s)
Apr 11, 2013 | Audio Players & Recorders
No pwer, sound or picture
start by checking the power at the mains terminal, then check the continuity of the power input cable. if its healthy then confirm that all fuse in the cable plug is ok.remove the cover and check on the switch mode power supply.conduct a visual inspection to acertain any blown component like the fuse, swollen filter capacitor, the burnt resistors and diodes. if they do not seem to appear phisically burnt then conduct a meeasuring test with a multimeter.
replace any faulty component and test the television by opening the power input fuse and connecting a 100w bulb in series and feed in the power. if the tv oscillates and the bulb lights up then gets dim gradually then the tv is working hence you can now remove the series test bulb and place back the fuse and connect all the cables in place and feed in the power and you see your tv lighting up
Sep 21, 2011 | Vizio L32 32 in. LCD HDTV
I have an lg 37"
Good day sir try to check first the power supply. The power supply of your tv is already faulty, try to remove the back cover of your tv then look for bulge up or leaky capacitor this capacitor produces low and unfiltered dc output that causes your unit to malfunction until the capacitor are holding enough power to bring the current up over the threshold point and power on the tv. But be sure to unplug the tv before removing the back cover of your unit and capacitor is much cheaper than the main board of your unit, just let me know if you want to do it I will guide you. Best regards.
Aug 15, 2011 | Televison & Video
Speakers pop or rumble when stereo is turned on
AMP HAS PROBLEM.. SOUNDS AS THOUGH THE LINE INPUT AMPS HAVE PROBLEMS IN AMP ALSO ONE THING TO CHECK WOULD BE TO DISCONNECT SPEAKERS AND HOOK UP RCA'S.. CHECK THE SPEAKER OUT PUTS WITH A DC VOLT METER TO SEE IF YOU HAVE DC VOLTAGE ON THEM IF SO YOU HAVE SOME SHORTED OUTPUTS
Apr 24, 2010 | Kicker ZR600 Car Audio Amplifier
Samsung sound but not video, cant even see to
Possible burned out light source or power supply. See if bulb is replaceable(SEE MANUAL). UNPLUG POWER, Look for burn damage to bulb. Do not touch bulb with bare hand.
Apr 12, 2010 | Samsung PN42A450 Plasma TV
Wires
Wiring Connections
1. TV TUNER
2. ANTENNA
3. POWER ANTENNA WIRE (Blue) – Connect to a motorized (power)
antenna and/or to a remote turn-on lead for an amplifier.
4. CONSTANT POWER WIRE (Yellow) – Connect the 12V PLUS constant
power wire to a live 12 volt wire in the vehicle. Before making a connection,
check that the wire you intend to connect it to is always live, even when the
car’s ignition is turned off. If a live wire is not found, route the wire to the
car’s fuse block and connect it to a live circuit there.
5. GROUND WIRE (Black) – Securely fasten the Ground wire to a grounded
metal part of the car’s chassis. If you cannot find an existing bolt or screw
to fasten it to, drill a hole in the metal and secure it with a screw. To ensure
a good ground, remove any paint or grease from areas where the wire will
contact the surface.
6. PARKING (Pink) – Connect to negative parking brake wire. This wire
MUST BE connected in accordance with federal, state and local laws. It is
the end-user’s responsibility to make sure this wire is connected properly.
7. ACC POWER WIRE (Red) – Connect to a +12 volt circuit that is only live
when the ignition is on. The best connection point is at the car’s fuse block
at the “RADIO” or “ACCESSORY” identified terminals.
8. LEFT FRONT SPEAKER (white, white/black)
9. RIGHT FRONT SPEAKER (gray, gray/black
10. LEFT REAR SPEAKER (green, green/black)
11. RIGHT REAR ( + ) SPEAKER (violet, violet/black)
12. FRONT AND REAR RCA OUTPUTS
13. CENTER RCA OUTPUT (Gray) – The center output must be connected to
an external amplifier for 3D or 6-CH mode.
14. SUBWOOFER RCA OUTPUT (Blue) – The subwoofer output is available
in all sound/audio modes.
15. DEDICATED DVD OUTPUT – Video output for rear screen and left/right
audio output for headphones.
16. AV1 INPUT
17. AV2 INPUT
18. VIDEO OUT (Yellow) - V. SEL output for rear screen.
Or you can go to link below for the manual page 4
http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ's/VM9510_DOC_OM.pdf
Good Luck and please rate 4 thumbs for the free answer
Mar 31, 2010 | Jensen VM9510 Car DVD Player
No power after replacing bulb
The solution from bjwjb posted on Dec 30, 2009 is absolutely correct:"There is a piece on the bulb cover panel that you take off in order to change the bulb that fits down inside the bulb assembly when you put the panel back on. The bulb cover panel and the part of the panel that goes down into the bulb assembly must be present or the projector will not power up (there will be no lights either)." I would add to that once the cover is placed back, but before the screws of the bulb cover are tightened, firm pressure should be place on on the bulb cover panel on the spot placed where the plastic protrusion (a plastic "stick" about 1.5 inches long that fits into a void in the bulb assembly) goes into the bulb assembly. You should/may hear a "click", indicating that the protruding plastic piece has been fully inserted into the bulb assembly and makes contact with whatever contraption is inside the assembly to enable power-up. If no pressure is exerted the plastic protusion may not extend down far enough to make contact to enable power-up. In such case the bulb cover panel may be slightly bulging in the location of the protrusion. You would still be able to tighten the bulb cover panel screws, because the plastic is flexible. In such case you may find that the screw closest to the location of the plastic protrusion may need pushed in more. In this condition, even though you may think the cover is properly placed, the plastic protrusion is not fully inserted and does not make contact and there are no lights or power. Just take of the bulb cover panel place it back following the instructions above.
I had already disassembled my projector and was ready to bring it in for service when I did an internet search and saw the advice from bjwjb. Thanks very much!
Nov 14, 2009 | Optoma EP739 Multimedia Projector
How to install motorcycle indicators to a motorcross bike, i`m not sure if the power supply goes to the switch or the lights? the bike is a KLX300R 2001 MODEL.
manual or electronic design?
basic 2 pole flasher relay manual design = battery -ve to lights return (metal shroud of bulb)
battery +ve to fuse holder (10A on 12volt system)
output of fuseholder to flasher unit +ve pin (sometimes marked input or L)
output of flasher unit to centre (common) connection of flasher direction switch.
output of one side (left or right) of switch to front and rear bulbs (wire from switch to front, wire from switch to rear) = centre pin of bulb
repeat last instruction for other pair of bulbs
Done!
Oct 14, 2009 | 2001 kawasaki KLX 300
Element Electronics FLX-3211B 32 in. LCD HDTV Logo
133 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
