Question about Pulsar Watches
I have a pulsar chronograph 100m the time keeping seems to be ok but, the buttons for stop watch, when stopping the sec,1/20 etc hand are not returning to zero. can u help. richard
  • withrow65 Apr 27, 2010
    either i am not understanding procedure or it is not working
    I understand what the crown is and your request to pull out to the first position, which i did. the second hand rotated to the 60 position, at that time i pushed the crown in but the second hand continued to rotate and would not stop at correct position.
    President:
  • 1,194 Answers
Thanks for using Fixya.
Try this: pull out crown to the first click, then push and hold button at 2 o'clock. When the hand is adjusted to the desired time, push the crown back in.
If this do not work, do the same using the button at 4 o'clock.
Good Luck and have a nice day.
Posted on Apr 27, 2010
  • Ranglo
    Ranglo Apr 27, 2010
    On the right side of the dial, there is a rotating thing.
    Pull that outside, you will listen different clicks, pull it to the first click. Then follow the above procedure.
  • Ranglo
    Ranglo Apr 27, 2010
    If it is like that then sorry to tell you that you will need to take it to repair centre.
    They will adjust it accordingly.
Pulsar Chronograph 100 m - The second hand on the left small dial (not the sweep second hand of the stop watch) has begun moving erratically. It appears to move for two counts and pause for three and then...
If your watch is solar powered the second hand performs this characteristic when it's in need of a charge. Try placing your time piece under a bright light for short time or in direct sunlight and see if this helps you with your problem.
Jul 21, 2011 | Pulsar Chronograph Watch
The timer on Pulsar watch does not line up at 12 when reset.
To set the timer hand on these models of Pulsar watches, do the following:
Looking at the face of the watch, there are two buttons and a crown on the right side. The TOP button is Button "A". - The BOTTOM button is Button "B".
There are 3 positions on the crown: IN (#1), FIRST CLICK (#2) & SECOND CLICK (#3).
First, pull the crown out to the second 'click' position (#3) ... This is all the way out. (STOP THERE! Pulling harder will harm your watch! Don't try to pull past position #3!)
Push and hold Button "A" for two (2) seconds. The dial will sweep around to the 12 O'clock position. You can advance the timer while the crown is in position #3 (second click out) to reset it back to the default position.
The manual says that if you pull the crown out to position #3 while the timer is measuring, the hand will reset back to the 12 o'clock position... I haven't tried that, so I can't confirm.
Jan 02, 2010 | Pulsar Chronograph Watch
How do I set the Pulsar Alarm-Chronograph N944-6A00
Short answer: You download the Operational Guide from Pulsar:
http://www.pulsarwatches.com/home2.asp#FAQ (look for N944 which is PGC series).
Longer answer: It is baffling to do this without the manual. You put the watch in -0- mode (crown fully in), pull the crown out to first stop, then us the A and B buttons to zero the 1/10th and second hands, then pull the crown out to second stop, then use the A and B buttons to zero the minute and hour hands. Then, you put the watch in "Time" mode (crown fully in), pull the crown out to the second position, and use the A and B buttons to set the time. You have no functioning second hand except for the stopwatch - in Time mode it acts as the calendar hand.
Dec 16, 2009 | Seiko Pulsar watch
Stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
Dec 01, 2009 | Seiko Coutura Chronograph Watch
How to set alarm on Pulsar Chronograph 100M
See PDF here to solve this problem.
Wish Pulsar would have included this info with their watches!
http://www.pulsarwatches.com.au/manuals_pdf/121_1.pdf
Sep 23, 2009 | Pulsar Chronograph Watch
How do I zero-out the minute hand of the stopwatch?
If thi do not work, do the same using the button at 4 o'clock.
Rate me, please.
Mar 26, 2009 | Pulsar by Seiko watch PF3359Men's 100m...
Rolex Daytona Chromograph
ok. bear with me. lol. on most watches without a chronograph. the second is the largest hand on the watch and naturally that's what most people refer to as the second hand. On a chronograph the "true" second hand is the little middle dial. It should always be constantly moving and the large hand should only move when the stop watch funtion is in play. The way to employ the stopwatch funtion is by unscrewing both buttons. The top button starts the action. Once pressed then large hand will begin. The little dial on you left will keep up with each minute that passes. To stop the function, press the top button again. To reset the stop watch, press the bottom button. The little dial on your right is simply military time. Hope that helps. Good luck!!
Apr 26, 2008 | Rolex Daytona 116520 Wrist Watch
Pulsar Gents Chronograph PF3501X1?
OK YOU GO TO SET TIME BY PULLING OUT PIN TO SECOND CLICK OUT. THEN USE THE BOTTOM BUTTON TO SET THE ALARM DIAL TO THE SAME TIME AS THE MAIN WATCH HANDS. CLICK BACK IN ONE CLICK WINDER THEN USE THE BOTTOM BUTTON TO SET THE ALARM. CLICK WINDER BACK IN FULLY AND PRESTO YYOU HAVE IT.
Feb 09, 2008 | Watches
Chronograph hand not resetting to 12 o'clock
for my victorinox, the crown out one position and the reset button (lower chronograph button) changes the minute hand and the top (start/stop button) does the 10th's of a second...crown all the way out and top (start/stop button) does 30 second intervals for the minute counter.
Feb 23, 2007 | Kenneth Cole KC1232 Wrist Watch
Watches Logo
165 people viewed this question
Top Pulsar Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
