Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Dishwasher won't drain or seems to drain to other diswasher.
Dishwasher won't drain all the way. Seems to backing up old water to the other dishwasher.
  • Fisher and P... Master
  • 713 Answers
Possible blockage at sink pipe where the drain hose connects to. the drain hose is attached to the spout on the pipe. remove the clip holding the drain hose to the spout, remove drain hose gently, put drain hose into a bucket and then turn unit on to a cycle. it should start draining straight away.if it does drain into bucket u have a blockage in the spout. put a small screwdriver into spout to unblock . then put drain hose back onto spout with clip and run a cycle. before i forget when and if the water starts draining into the bucket turn off the unit so u can put the drain hose back on. if u need more help please reply. good luck.
Posted on Apr 30, 2010
No control panel lights on Bosch SGV43A03GB/17 diswasher
i have nearly the same problem ! but my one have no water left in it !but pump still running if i put bucket of water in it will drain it away but no lights on panel and anyone know what that is please ?
May 14, 2012 | Bosch 24 in. SGV43A03 Built-In Dishwasher
My diswasher will not drain, it seems to have completed the cycle but the basin is full of water when it finishes.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Mar 25, 2011 | GE 24 in. GSD6200G Built-in Dishwasher
I Have a candy dishwasher about 4 years old after washing it seems to leave a gritty chalky residue I have tried added salt, rinse aid and putting a diswasher cleaning solution through it nothing seems to...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 13, 2011 | Candy CD623X Free-standing Dishwasher
I have a whirlpool du1055xtsq2 diswasher which is not cleaning. The motor is running and the drain is clear. It seems that the water isn't spraying from the wands it is just slowly flowing through. I have...
If you live in an area where the water has a lot of calcium, the deposits can build up in the passage for the water.
Also, the fins on pump may have broken inside.
If you need service in Los Angeles, Allen And Sons is a good company. http://MyApplianceService.com
They have a forum on their site, it may also be helpful for you.
Feb 13, 2011 | Dishwashers
I have a whirlpool gold model GU1500 diswasher. When the rinse cycle ends the water pumps out into the garbage disposal like it should, but then water backs-up from somewhere into the bottom of the...
Seems you answered your own question here. You need to make an air gap in the drain hose - take as much slack as possible and make a curve (upside down U) under you sink as high as you can go. Make sure you clip ot to back of the cabinet to stabilize it. Good luck
Jan 11, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Bosch Diswasher won't pump water out after cycle
it needs a new drain pump for around $65 dollars. the install will take close to $90-$120.
Apr 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My frigidare diswasher is leaking from a left side black hose
Check the hose first - it could be split or damaged esprcially if it's old. Check all the clamps to be sure they are tight. Chack all connections to the dishwasher and drain spur under the sink. Check the drain trap fro any leaks.
Mar 27, 2009 | Frigidaire Dishwashers
Bosch dishwasher leaving residue
You either need a water valve, if the dishwasher isn't filling with enough water, or you need to run a dishwasher cleaner through it.
Apr 07, 2008 | Dishwashers
Diswasher
Check the float switch. If it is stuck the machine will start but no water will be allowed in and the pump will turn on to drain the non existant water. This happens often when a small item gets under the float preventing it from allowing the water valve to open. Find the float in the bottom of your machine and make sure it moves freely.
Jan 15, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
393 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
