Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
Mower cuts off when blade is engaged.
I replaced the cable that engages the blades now when I push the engage lever the mower cuts off. Not choking down or stressing the belt, just cuts off like when you get off the seat with the blades engaged.
  • 54 Answers
Not familiar with this model, but a thought, check for a kill switch.
Posted on Apr 28, 2010
Husqvarna Riding Mower when turn lever blade will not engage.
If the engagement is done by lever, yes it is controlled by cable. It could be disconnected or the cable could be broken.
Oct 29, 2016 | Husqvarna Garden
Why won't blade engagement lever move?
The cable is rusted,not allowing it to move,or there is something jamming the mechanical parts on the deck.
Oct 19, 2014 | Garden
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
2000 craftman lawn tractor 917.270822 blades will not engage
If your blades won't engage when you raise the lever to engage them AND that lever moves freely without the normally expected resistance, then you've lost the cotter pin that connects the lever rod to the mower deck assembly. Very easy fix! Using the mower deck raise/lower lever, lower the mower deck to "down" position. Now, lay on your side along the right side of the mower and look up (use a flashlight) under the mower at the top of the mower deck while moving the blade engagement lever "up" (which pushes the connected rod down). At the end of the rod, you will see a hole where the mower deck and rod connect. Align the hole at the end of the rod with the matching "pin" on the mower deck (you'll see it) and insert a new cotter pin to secure them together. Use a nail if you don't have a cotter pin. Voila! you are done. The blade engagement lever will now engage/disengage your mower blades successfully. Just remember that mower deck must be down, or lowered, before you engage the blades!
Jun 22, 2012 | Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
855 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
