Question about Maytag Atlantis MDG8600AW Gas Dryer
How do i get access to clean out the dryer vent?
  • yadayada
    yadayada May 11, 2010
    BY WHATEVER MEANS IT TAKES.
  • 45 Answers
You will have to disconnect it from the back of the dryer and wall. then blow it out.
Posted on Apr 28, 2010
My dryer is very hot to the touch
It is most likely clogged with lint, pull the lint filter and clean down in the hole it slides in. remove the vent hose and clean out the dryer and make sure the access tube going out is not clogged, remove access panel and clean anything you can see inside the dryer. Be sure to unplug the dryer before you clean out the inside. it could possibly be your high limit thermostat but usually when it goes out it burns out the element pretty quick and you have no heat. Hope this helps
Apr 13, 2014 | GE GTDX300EMWS Dryer
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
No heat in dryer
I have tips on dryers in my profile. I would clean all the exhaust vent tubing in this and try again to see if heat will work
A moister sensor detects any obstruction of lint in the vents and shuts the heat off until it is cleaned out
It is a fire hazard and all dryers made the past decade all have this option installed
May 24, 2010 | Dryers
Dryer isn't drying as well as normal.Lint filter is clean.Doesn't seem to work any different on timed dry or auto dry.I have electrical exp. but no dryer exp.What should i check and how do I access it?
i belive you should check the vent hose from the dryer all the way to where it exits the house... that's usually the problem when dryers aren't drying as well as they shoud... lint wil start to cake on the walls of the vent and either create a complete block or slow the air down enough to keep it from circulating like it should
Feb 14, 2010 | Whirlpool WED5300S Electric Dryer
My hotpoint dryer doesnt dry well. What do i must review?
Electric dryer? Try cleaning lint from the vent & inside the dryer - unplug it, remove the back, vacuum everything including inside the exhaust vent which you may be able to access better by removing a few screws. Poor airflow caused this problem with my dryer.
Nov 19, 2009 | Washing Machines
Kenmore 400 Series electric takes ver long time to dry.
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Mar 09, 2009 | Kenmore 73952 Gas Dryer
Very Hot Top
It appears that your venting system is restrictive to a point that the hot air coming from the exhaust of the dryer cannot get outside due to excessive lint in the line. If possible, can you use a flex line and temporarily vent it out thru a window until your hard-piped vent dries out and can be cleaned properly? These dryers have thermal overloads to shut them down if they get too hot but since you mentioned the heat was near the top in the back.. I would make sure the power cord connections are tight.. ( do this by unplugging the dryer from the wall receptacle) the open the access cover were the cord enters the back of the drier.. then use a screwdriver and and make sure all 3 or 4 wire terminals are tight. A poor or loose contact there is resistive and may get hot enough to cause a fire. Make sure to remove or disable power BEFORE servicing this area.. Hope this helps..
Aug 31, 2008 | LG DLE9577 Electric Dryer
Kenmore dryer
unplug unit/dicnnect power. 3 1/4in screws will remove lower panel, allowing access to remove lint(if excessive amount i would also have venting cleaned and or replaced.
Feb 21, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Atlantis MDG8600AW Gas Dryer Logo
49 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
