Question about Compsee Apex II
My scanner will not reboot
My hand held scanner will not reboot(Apex II)
Reset check engine light
Most of the larger-chain auto parts stores have hand-held OBD II scan tools and will allow you to use them there at no cost. Plug the scanner into the OBD port and read/record the code(s) stored in your car's computer. The scanner should also have a function that erases stored codes and turns off the "check engine" light. Then, ask the counterman/woman what the code means and decide whether or not to have the malfunction repaired or serviced. Good luck.
Sep 27, 2013 | 1994 Mercedes-Benz E-Class
Error message apex ii
retry and reset it and retry
Dec 10, 2007 | Compsee Apex II
Can Not Logon to Hand-held,will not accept supervisor password
Hi
If it is still not working, try to bring it on factory default.
Press Red + Blue + Scanner button. It brings you in BoosT menu. Type here " .25326 ".
The above statement is dot25326.
Irfan
Sep 15, 2009 | Psion WORKABOUT PRO
Hand held pro 83 scanner
http://support.radioshack.com/manuals/ome20-501.pdf
May 30, 2009 | Radio Shack Pro-82 Scanner
Not hearing certain frequincies
not all scanners will pick up the same, the hand held can't pick up frequency as far as the other one.
Mar 11, 2009 | Radio Shack Pro-97 Handheld Scanner
Apex II Scanner is reading error 44
With ours, we have to press F1 and then Enter, then a location (in our case a Pallet Number, say M0100) - then we are able to start "zapping".
Dec 10, 2008 | Compsee Apex II
Error 20
Sometimes i can get it to retrieve on another station. Maybe its a communication issue and taking too long to retrieve so it timed out.
also you can change the program to wait longer before timing out.
Jun 12, 2008 | Compsee Apex II
Error Message
Click Alt R
Apr 22, 2008 | Compsee Apex II
Technical Manual
It's here, 56 pages.
http://www.fixya.com/support/p189326-compsee_apex_ii_coapii12bkls/manual-18710/page-1
Mar 28, 2008 | Compsee Apex II
Compsee Apex II Logo
35 people viewed this question
Top Compsee Computers & Internet Experts
David Payne
David Payne
Are you a Compsee Computer and Internet Expert? Answer questions, earn points and help others
