Question about Karcher 1750 psi Electric Pressure Washer
Where can I find a replacement gas cap for a Karcher/Briggs & Stratton 1750 G power washer?
SOURCE: Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Posted on Jun 14, 2008
  • 92 Answers
SOURCE: Instruction Manual
Dear fslook,
Try by entering in google KARCHER. Then find the home page. Find where to choose your country, and choose...INTERNATIONAL.
Then press MANUALS........then enter the model.
Now if you do not manage I give you some hints myself.
Always attach gun and water supply before switching on electricity. I advise that you start the machine without a lance first. See that when you close the gun the machine stops. If it does not stop, press quickly the gun again, and then switch off the electricity. If this happens you have a fault.
Now let us say the machine stops as it suppose to do, you can put on the lance. If you have a variable lance change from low to high by holding from the lance and not from the gun.
When you use chemical or detergent see that afterwards you rinse with pure water.
When you finish using machine, NEVER store with pressure in the system!!
Lubricate with silicon grease, connection of "gun hose" to machine.
Never use high pressure on car paint work or more important " not on car tyers"!!
Electricity and water do not go together. So inportant that you have a safety circuit breaker where to plug the machine.
If machine starts jerking when gun is closed or when gun is open, STOP instantly, and give to technician for servicing.
Never leave the machine on and with pressure when you are going somewhere. Always switch off and release pressure.
Regards,
MG.
Posted on Nov 05, 2008
  • 389 Answers
SOURCE: I was using the pressure washer and it stopped
This problem, where the unit continually switches on and off when the handgun is closed, is quite common. Unfortunately it has at least six different possible causes, only two of which are easily checked.
The first thing you can do is look for leaks.  Even the slightest leak will cause this pulsing because the unit gets up to pressure, switches off, loses pressure, switches back on again, comes back up to pressure, switches off... and so on.  This repeated switching is not good for the motor and should not be allowed to continue for longer than necessary to observe what's happening.
So... 1. Does the handgun shut off completely, or does it drip? If it drips, it may simply be because a seal has failed. The handgun can be dismantled, checked, and any defective parts replaced; be sure to lubricate O-rings with silicone grease when reassembling. As a last resort, the whole gun may need to be replaced.
2. Are there any visible leaks at the high-pressure hose screw connections?  If so, most likely an O-ring needs replacing - again lubricate the new one well with silicone grease.
3. If there are no visible leaks, either from the gun or from the connections, all other possible causes are internal within the cylinder head or control head of the pump. New parts will be needed and this normally calls for a professional repair, although it's not beyond the scope of a truly competent amateur.
I hope this helps. Any further questions, just ask! Please remember to rate this response.
Posted on Apr 17, 2009
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
seanpwright
  • 2030 Answers
SOURCE: My Karcher 1750 psi electric pressure washer is
thats normal, it is reducing the built up pressure that is not needed until the trigger is pulled.
Posted on Apr 01, 2010
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
Engine Stops after 10min run time
check the breather hole on the gas cap.
run the engine with the cap off and see if it still stalls.
Apr 20, 2010 | Briggs & Stratton 020272 Elite Series...
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Oct 02, 2009 | Honda Karcher G4000RH Pressure Washer
Briggs & Stratton engine loses power
Hello herb1007
If it is running it would burn any oil off the top of the piston. (that got there when you tipped it). It sounds like you carburetor needs cleaning. There are sprays on the market that sometime help with this.
Jul 15, 2009 | Briggs & Stratton Garden
Electric or Gas?
Pressure washers are either electric or gasoline powered. Electric pressure washers are low maintenance and quiet. These generally are for light duty. They are handy where you need to work on small confined area, however you need to run power to them and have a pressurized water source. Also the National Electrical Code and Underwriters Laboratories now require ground fault circuit interrupters (GFCIs) be use when operating an electric pressure washer. Gas models are recommended for tasks that require more power, such as paint prep, heavy vehicle cleaning, or cleaning heavily soiled concrete.. Gas models start with PSI of 1750 and go as high as 4000. They also offer more portability, as they are not limited by electric cords. Also some gas models can draw water from a source other than the garden hose, which allows you to work away from a water line. All gas models have 4-cycle engines and run on regular unleaded gas.
Aug 27, 2008 | Briggs & Stratton Power Products 1539...
Pressure washer wont idle and run
check the pressure replace valve or a bypass valve
Jun 05, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 1750 psi Electric Pressure Washer Logo
65 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
