Question about Veritas Backup Exec 10 for Windows Servers Advanced Disk-based Backup Option for PC
New tape drive
I just installed a new tape drive and card and i cannot see the drive. My old tape drive is still visible but the new does not show up. It shows up in the system as installed and working, but the veritals 10.00 can't seem to find it.
Any ideas?
Thanks in advance for you help.
Robert Peet
Ithaca Schools
bpeet@ithacaschools.net
Didn't realize i had to install a Veritas tape driver to allow Veritas to see the drive.
Posted on Mar 25, 2008
The printer is seying change cyan catrige
If you did not replace the cyan cart with a new one, the old one is likely empty, too. If it's a new one, take it out, and wipe the contacts off (also, some HP carts have tape across the contacts when new, and you have to remove the tape before installing the cart.)
Sep 12, 2014 | Office Equipment & Supplies
Have an old Iomega Ditto tape drive Easy 800 and Ditto Tools software for Windows and Windows 95. Want to move data from old tapes onto Vista Op Sys and then onto a CD. Will this old software install on...
Is it possible to find an old computer running an old version of Windows, and then to connect the tape-drive to that computer, and then to copy the files onto a folder on that computer?
Then, if that computer has a network-card, you can "share" that folder, so that all computers on your network can then access that "shared" folder, i.e., to copy the files, and then to burn them to a CD-recordable.
May 05, 2011 | Iomega Ditto 800 External Tape Drive...
I have a compaq evo w8000 desktop and want to install a sata drive instead of the built in scsi drive. I can install windows xp (i've got the sata card drivers and pressed F6 etc, that all works fine)...
ok a very very old DT , desk top, ive done this vast times, back long long ago... 17 years old, you use this old of hardware why?
we dont use XP in uSA its VIRUS magnet. horred
and no updates, now, means will get worse each day forward in time. endless...
has built in, SCSI chip. l Ultra160 SCSI and Ultra ATA/100
that ATA means PATA port, not SATA back then.
my wild guess now is that someone put an a new SATA card in the PCI slot, (ive done so vast times)
The BIOS in your machine will never support that.
that means you can not boot to PCI SATA. for sure.b
but wait, the better SATA card works just like a new Adaptec
ultra160 card that if love.
the new SATA card has what is called a BIOS extension ROM on said card, and a new HOT key to access it.
some are CONTROL +A but each maker of said card ,does as he pleases, so READ THERE MANUAL.
you set it to boot o STAT port and it does if port 0 is bootable drive. SATA.
here ill take you now to newegg.com and show you hardware that works.
if you showed a photo of your CARD and # id have answered, 10x better. !!!!!
i cant shop for you, nor pick SATA 1 ,2 or 3 for you.
but here
https://www.newegg.com/Product/Product.aspx?Item=9SIAC0F5KW5808&cm_re=sata_card-_-9SIAC0F5KW5808-_-Product
the big trick here is making sure you relic MOBO
supports the current levels of PCI>
like above
32-bit / 66MHz PCI interface compliant to PCI Rev 2.3
(Backward-compatible with PCI 33
https://www.promise.com/media_bank/Download%20Bank/Datasheet/FT_TX2300_DS091406.pdf
Control +F (see page 11)
https://www.promise.com/media_bank/Download%20Bank/Manual/FastTrak_TX_Series_User_v3.2.pdf
warning, ive run in to big problems using very old relic
motor-boards that use the very old PCI signals and levels.
and will fail on some newers card
I warned you,
the above reads good. for that. (hope )
now my question why use such old hardware.
when goodwill has truck loads of 10year old pCs for $20
why, love of XEON?
id trash it.
find a use desktop with SATA ports, ALL DO now, or scrapped.
May 08, 2017 | Compaq Evo Workstation W8000 PC Desktop
How do I read a hard drive taken from a WD Media
go into control panel click on administration tools storage there you can initialise and format
Jul 30, 2009 | Western Digital Media Center WDXF1600JB...
2nd hard drive on Dell Dimension 8300 ( both ATA)
setup the original harddrive as master and the new one as slave then the drive that comes up as c will be the master and the others will follow suit and when you install the games just change it in the install
Jul 20, 2009 | Western Digital Caviar SE16 WD5000AAKB -...
Transfer 8mm,hi8,digital 8 to pc
Since my request..Found i could answer my own questions. Brought firewire card with 6 pin socket.Also brought a cable with a 6 pin to fit the firewire card @ a 4 pin on the other end for the camera .Found my install cd. Loaded the USB installation. Got my connection completed between the camera @ the computer.With regard to the tape formats no problems at all.With nero 6 not sure yet.My home movies go back as far as 1989 and the quality is as good as new.Hope SONY don't stop making the dv tapes. With the external hard drives for editing @ storage need an answer for capacity James from Auckland New Zealand.
May 16, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
Old Tapes work new ones don't
I'm having this exact same issue and according to the DELL tech it is common. What I had to do is keep using the tapes until they started passing. I bought 2 brand new cleaning tapes and ran two cleaning jobs before it would pass. My daily tapes are passing, and after several retrys my weekly tapes are passing. Since my Monthly tapes occur so infrequently, I'm just taking one of the Daily tapes out of the rotation and using a Monthly tape until it passes. It's either this or buy a new tape drive.
Oct 28, 2008 | HP DLTVS80 (C750760008) Tape Drive
Installed identical replacement STT320000A but won't recognize tape
The STT320000A is IBM version? some IBM version STT320000A will rewind the tape when inserted. But It can recognize the media after rewind. If can't, try to used the cleaning cartridge or change one new media. regards
Jul 20, 2008 | Seagate 20GB TRAVAN SCSI 5 1/4 TPE DRIVE...
Tape drive replacement trouble
drivers are a simple solution..here's a link for printer drivers, which you can jump through to find tape drivers, with the dell model number.
Mar 10, 2008 | Quantum DLT VS80 DLT Tape Drive
Veritas Backup Exec 10 for Windows Servers Advanced Disk-based Backup Option for PC Logo
187 people viewed this question
Top Veritas Computers & Internet Experts
Mike
Jax Planet
Jax Planet
 steve
steve
Are you a Veritas Computer and Internet Expert? Answer questions, earn points and help others
