Question about Husqvarna Forest & Garden 125c 17" Curvgastrimmer
The trimmer ran fine for 10 mins. then would not start back up........What would u recommend??????
  • 64 Answers
Either its not getting fuel or the coil or spark plug are no good.
Posted on Feb 23, 2011
    Problem Solver:
  • 8 Answers
If new,,,it's under warrenty.
Posted on Apr 27, 2010
Needing break down on starting assembly! My start cord is fine, but dose not grab anything when I pull.
Danny by the pull cord on the back are two wings that come out when you pull the starter. They are on springs and fly out to grab the wheel. Spray these with lube oil and then let them rest for 10 mins then try.
Oct 17, 2013 | Stihl FS 85 Weed Eater
Murray m2500 won't start after one day of having it
bad coil in it, i had bought a m2500 murray weedeater from walmart .did same thing i replaced the coil. bad when you buy something from wal mart and have to get it fixxed before you can use it. now it works fine
Apr 23, 2013 | Cars & Trucks
18 volt trimmer is new, first time I charged battery over 10 hours it only ran for about 15 mins. charged again until green light, over 3hours used about 3 times , start with full charge, only lasts...
This could be the life of the battery as there is another question along much the same lines. I suggest that you take it back to the dealer and discuss it with him and take it from there. Take into account that any attempt to fix or adjust any part of the machine will void your warranty.
Jun 13, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Trimmer is one yr old. Battery was kept inside during the winter and now won't take a charge. I called the Worx service nbr. Waited for 35 min. Went on the website Worxbattery.com and can't...
You can buy replacement batteries on ebay. If you can afford it I would highly recommend buying a quality trimmer at your local hardware store. I have had experience with the Worx trimmers and they are just plain cheap.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Poulan Twist N Edge TE 450 CXL - has ran great for 10 years. It still runs great and fires right up every time - except now it will run for about 8-10 minutes, then it will just abruptly die. It then...
Hello, W/D here.
Check the pinhole vent in the fuel filler cap. As fuel is removed when the engine is running, air is pulled into the tank. If the vent is blocked, a vacuum is formed, and fuel cannot flow. After a period of down time, air infiltrates back into the tank, and the engine can be re-started. You can test this out just by cracking the cap open after starting the engine, just enough to allow air to get into the tank.
Best regards, --W/D--
May 02, 2011 | Poulan 17" T&E Gas Trimmer
CRAFTSMAN WEEDWACKER 316-791860, WILL NOT START. HAS SPARK, FUEL LINES FILL UP, WAS RUNNING FINE, DIED, STARTED NEXT AM, RAN 5 MINS THEN DIED AND WOULDN'T RESTART
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
Apr 07, 2011 | Craftsman Convertible 25cc. Gas Line...
This problem started about two weeks ago. when i started the car and left the house it was running but the rpms would drop and the car would shut off but start back up immediately while going tdown the...
This is a good indication of a bad ignition control module. The module is located under the coil pack (where all of your spark plug wires come from) and may be testable. Auto Zone says they can't accurately test this part but it is $100 to replace it.
Mar 05, 2010 | 1991 Buick Park Avenue
I have a craftsman 25 cc string trimmer with fuel problems. After winter, ran tank of good fuel through it and it worked fine. Added fuel (unknowingly with water in it) and it ran on a slow idle and...
You shouldn't notice a difference if you remove the air filter. So I would replace it. Also if you are using compressed air to clean or blow-out the carb. Be careful, its not recommended and could make it worse.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Bad running craftsman 25cc trimmer 4 yrs old
You need to do a couple of things to get your trimmer back on track. First of all pour out the old gasoline and get rid of it. Then remove the spark plug and go to an auto parts store and get a new one just like the old. If you have your manual, check to see what the recommended spark plug gap is gap it to that specification.
Finally remove the air filter and clean it or replace it as necessary.
Once that is all done, but some new, fresh gasoline. Then put in the new plug and the new gas and u will be good to go. please rate this answer as a FixYa cause it is.
Feb 25, 2009 | Craftsman 25cc Gas Line Trimmer
Husqvarna Forest & Garden 125c 17" Curvgastrimmer Logo
116 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
