HU-5540 4 Port USB2 Powered Hub will not work with my computer
Hi
I have purchased a TRUST HU-5540 4 Port USB2 Powered Hub, the hub powers up from the mains but when I plug in the USB lead { Computer To Hub } nothing happens, I get a box come up New hardware found I click on ok
It searches for a USB 2 Device then cannot find comes up please insert disc which does not come with the hub ??
Can anyone help solve this problem please ??
I have a Dell Dimension 2400 bought in 2005
Many thanks
Maurice
SOURCE: helpp! exceeded the power limits on its hub port?
Shut down the computer, unplug the power cable and wait 10 seconds. Connect the power cable and start the computer. That would reset the power on the hub port.
Posted on Jan 30, 2008
  • 3 Answers
SOURCE: Ipod
I think you have a sort in your ipod.
I will say a bad battery will cause this.
You have to open it and see if you make it to work without the battery.
Posted on Aug 17, 2008
  • 36 Answers
SOURCE: Dell Inspiron 8000 - USB2 Universal Host controller
you can plug your pen drive backside. if its cant work your computer speed is slow.
Posted on Sep 21, 2008
egoboss187
  • 53 Answers
SOURCE: Ipod
maybe bad ipod try another computer
Posted on Nov 29, 2008
  • 238 Answers
SOURCE: no bootup
I've seen systems that default to booting from the latest installed drive. I suspect that your BIOS has this set. Go into the setup and check. If it has this set, set it to the drive you want to boot to. This will probably keep happening if you like to boot the system without the drive connected unless their is a BIOS update.
Posted on Jan 23, 2009
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
Compatible charging cables for phillips go gear hdd1630/17
Apr 10, 2013 | Philips HDD1630 MP3 Player
I PLUGGED MY MP3 PLAYER INTO MY LAPTOP USB PORT AND IT USED TO WORK NOW IT SAID THE USB DEVICE HAS EXCEEDED ITS POWER LIMITS OF ITS HUB PORT AND WONT WORK NOW
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Sep 05, 2011 | Computers & Internet
USB POWER
Jun 13, 2011 | Computers & Internet
When i put the USB cable and connect to the LAP, its not getting charged. How can i solve the problem? do i need to install any software?
Hi - when you say "LAP" I assume you mean laptop or notebook computer. Some computer USB ports do not have sufficient power to charge (or operate) devices like cellphones, GPS, large external hard drives, etc. You may be able to charge if you disconnect all other USB devices that aren't needed to run the computer. In order to get around the problem without having to do all that, either purchase an external charger for the GPS (which may be fairly expensive) or purchase a powered USB hub.
An external powered USB hub looks like a traditional USB hub, except for the fact that it has a power cord to connect to your home power outlets. The power cord will often look like AC adapter. The powered USB hub is ideal because they provide additional USB ports, are fairly inexpensive, they provide all the power for the USB devices that are connect to them (the computer's internal power supply is not used) and it can power or charge devices connected to them without needed the computer to be powered on. Simply plug the USB hub into a USB port, and AC power source - then connect the devices that need a large amount of power to the hub's USB ports instead of the computer's USB ports.
The parts included with powered USB hub (clockwise from left): USB hub, USB connecting cable and AC power adapter.
Many powered hubs will work without the power adapter - however they will supply power to the devices connected from the computer's internal power supply.
I hope this helps and good luck! Please rate my reply. Thank you.
Jun 08, 2011 | GPS
A USB device has exceeded the power limits of its hub port
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Mar 11, 2011 | HP Compaq nx6110 PC Laptop
I DON'T KNOW WHERE TO PUT THE USB CONNECTOR
If you only have one USB connector then you can purchase an USB hub which may have 4 or more ports (I suggest you get a powered USB hub). Then plug the hub into the computer's USB port and you now have several USB ports.
Jan 04, 2010 | Canon CanoScan 4400F Flatbed Scanner
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Power Surge on Hub Port
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
4 Port USB2 Triangular Hub HU-4840 is no longer being recognised by my computer
humm u need to format your pc & reinstall os try to connact if problem occers then u have to change the usb prot its has been short
Sep 06, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
