Question about Black & Decker Garden
The spool keeps unravelling and breaking into small pieces scattering all over the lawn. Black & Decker Strimmer Gl 656
SOURCE: how can i repace the
Instructions can be found at: https://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gl550_uk.pdf.
If the line keeps getting too long, it's because swivel 14 in diagram 7 was in the wrong position when you inserted the spool - just move it to the ouside position, re-insert the spool and away you go. Frankie.
Posted on Jun 11, 2008
  • 4 Answers
SOURCE: got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Posted on Jun 01, 2009
SOURCE: Black & Decker GL720 Strimmer not working
Hi there, I just thought I'd mention that I also have a Black & Decker GL720 with the same problem. I'm pretty sure it is less than 1 year old too, so well within the 2 year manufacturer's guarantee here in the UK. I think it may be a UK specific model and the phone number from MrFixIt looks like a US number.
I have tried taking the plastic casing apart, but with no luck, as the two halves won't come apart easily, even after removing all the screws. Ah! OK, I've found out the reason that it wouldn't come apart now, there is a screw hidden under the 123 sticker.
It's all apart now, and I see what is wrong, there is a belt running between a small cog and a large cog, and in my case the large cog has partially melted and the belt has come off. Unfortunately, I'm not sure I can get the replacement part now. Hopefully with yours, MrFixit, the belt might have just slipped off, fingers crossed.
Anyway, here is a service diagram of it in case it will help anybody, but as you will see it says only certain parts can be ordered. If anyone locates a supplier of all the parts please post it here.
Many thanks
Simon
Posted on Jun 03, 2009
  • 81 Answers
SOURCE: Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Posted on Apr 13, 2010
  • 133 Answers
SOURCE: GL 320 String trimmer - nylon string keeps breaking
It sounds like the sting is wound backwards. Try winding a short piece in the opposite direction. If it is backwards, it will be gone in a hurry.
Posted on Apr 20, 2010
Line does not advance.
I'd try to remove the spool to see if the cord is out. The cord may also not be wound on the spool correctly. I try to keep tension on the cord as I replace the spool to keep the cord from unraveling.
Oct 19, 2012 | Black & Decker String Trimmer Cordless 12"...
Apr 16, 2010 | Black & Decker String Trimmer Cordless 12"...
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
How to restring a black & decker gl 565 strimmer
Hi Bill,
If you turn it upside down you will see the strimmer head. You should be able to remove the protective cover which will allow access to the string cassette. The rest is self evident.
Feb 14, 2010 | Black & Decker Garden
How do i replace strimmer wire on a black and decker 315
how do i replace a spool and line on a black and decker GL20 strimmer x
Sep 10, 2009 | Black & Decker Garden
GL 315 strimmer chops the line up into small pieces and goes through a reel in minutes
the spool control teeth have worn out and is continuesly feeding line take out spool look at teeth in head if good replace spool if not need new head and spool
Jul 07, 2009 | Garden
Gls 220 auto strimmer
When putting new line on, it must be wound clockwise onto the spool
Jim
Jun 30, 2009 | Black & Decker Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Jun 01, 2009 | Black & Decker Garden
How can i repace the line on a black & decker strimmer gl550
Apr 20, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
633 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
