Question about Indesit WA 115 Front Load Washer
Washing machine (WIE157S)
On starting the machine, you can hear some water going in. Then it stops and a notice comes on where it usually tells you how long the cycle has left. the notice says H2O and it doesn't complete the cycle, it doesn't even take the soap powder away out the draw.
Could you please help and advise, as I have tried everything.
Many thanks
gill
  • carlawarla Apr 17, 2008
    NOT SPINNING PROPERLY CLOTHES STILL SOAKING AFTER SETTING SPIN ON 1500 RPM AND ITS DISPLAY IS SHOWING ERROR CODE F03
  • Anonymous May 29, 2008
    washing machine wd420, start machine, water goes through to powder in top, machine starts, but no water goes in to machine, does not spin, then lights flash on front to show their a problem
    President:
  • 1,294 Answers
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Pl rate if helped..................
For guest dated May29:
If you still don't have water going into machine you have to plug off the wall mains, open the top of your machine to see if the three tubes are connected to the dispenser tray. Connect securely & check for leaks before you close the top. You did not say there was any leak, so this may not be the problem; it could only mean that the inlets were clogged. Another way would be to clean out your dispenser tray.
Posted on Jun 05, 2008
  • prem mathew Jun 05, 2008
    killy & guest :Water inlet hoses coming in to machine is what i mean.
    For carlawarla:
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe would be good too.
Hoover 700 LA keeps overflowing
Hi just read you posting.Now fortunately I have the same machine.Just a couple of questions.--1-- does the machine flood at the start of the cycle when it is filling for the wash or in the rinse cycle? 2---At anytime while it is filling does it start to wash? Now try this for me, Turn the machine on at the start of a cycle so it starts filling and then when you hear the water going into the machine turn the power off at the power point. After you turn the power off at the power point can you still hear water coming into the machine?Please reply with additional information to the questions because with those questions answered I will tell you the exact fault and guide you throe the repair.
Jun 20, 2010 | Washing Machines
Indesit wie157s - H2O fault, prewash water ok but no main water
this is just a guess, but try changing water temp. settings for main wash- perhaps one of your water inlet valves is clogged or defective?
good luck!
Apr 17, 2010 | Washing Machines
Washing manchine water overflowing over the top
where the hoses go into the machines you will notice those valves are controled by solnoid switch thats what starts and stops water flow as you turn selector knob you should hear them click if that turn off water supply remove hoses from back of machine check if filter screen is in place and that there is no trash keeping valve open p.s switch from hot and cold to see which one needs to be replaced or repaired
Nov 19, 2009 | Frigidaire GLWS1339CS Top Load Washer
I just moved into a flat with the WMA641 w Beko Washing Machine. I loaded it and turned it on : settings : Delicates 30 degrees. Pushed the on button and nothing happens. after few seconds the on light...
turn the machine off at the wall , leave off for 30 secs , switch back on
and push the start button
give the door an extra shove as this may not be fully closed
the on/off button will be a push in type , the start button is usually much smaller
Oct 23, 2009 | Washing Machines
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Kenmore serie 80.does not stop filling water in and does not star
Yeah I've seen that happen a many of times. Take the back of the control panel off and where your load size selector is you'll find a little hose that's suppoed to be attached to the side of it. just reattach it and you'll be back up and running.
Almost all washing machines use a pressure tube that tells the washer when to stop filling with water. If the tube comes off for some reason the washer will never stop filling and that's an instant flood if you don't notice it quick enough. Also a hole or puncture of any kind can be causing ti to never stop filling as well.
Hope this helps
Jason
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
this can be more than one fault but try the following:
take top off. find the pressure stat - this is usually a round device with usually 6 elec connections or so and a small diameter hose going to it. unclip the hose and blow hard to clearv any blockage. also check hose for any split.
leave this hose off and connect another hose of same diameter. start machine so it fills and pressurise the hose by mouth. you should hear a click and the water stops coming in.
if none of this works, then there may be a fault with the main module
Jul 16, 2008 | Indesit W 123 Front Load Washer
My washing machine will not stop filling up. When you switch it on and set it to run on a normal wash, it will start ok and pump out some of the water but then it doesn't seems to stop filling up with...
possibly no part at all.
take top off and locate the pressurestat. this is usually round with up to 9 elec connections and a small diameter pipe as well.
take pipe off and blow down hard and check no split in pipe.
to check pressostat itself, put on a piece of pipe of the same diameter. put machine on fill and gently blow into the pipe ie pressure. you should hear a click and the water will stop coming in
Jul 15, 2008 | Washing Machines
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Feb 10, 2008 | Indesit W 123 Front Load Washer
Indesit WA 115 Front Load Washer Logo
132 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
