Question about Samsung 7.3 Cu. Ft. Electric Dryer
My samsung dryer does not stop drying even when the clothes are hot it continues to run. I have it set on sensor dry but will run all day if I dont stop it.
  • 8 Answers
You need to replace the main PCB board. They have upgraded the board.
Posted on May 06, 2010
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
In the auto dry mode the the dryer continues to add time to the cycle even if the clothes are dry. I suspect the drying sensor is not working.
You would be correct.Try and run the dryer empty for a few minutes if the time does not decrease then replace the sensor bars. In rare case the control module needs to be replaced.
Dec 24, 2010 | Samsung DV218AEW Electric Dryer
Dryer does not stop. time shows flashing rectangle.Is this normal
Hi There
I have this for you to read this should get you on the right track. Let me know how it went.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you for writing to fix ya.
Best Regards Richard
Dec 23, 2009 | Samsung WF203ANW Front Load Washer
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
Aug 05, 2009 | Dryers
I have a Frigidaire Dryer model GLER331AS1 and one day it was all lite up with heat I had to manually turn it off, after that it will run but it wont turn off if it's not on the minutes drying time it just...
hi Gwen. I can help you.
Jun 08, 2009 | Dryers
Dryer will not turn off
May 20, 2009 | Dryers
Kenmore 11070702990 Gas Dryer - Timer does not work
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Dryer heats &revolves but clothes do not dry
if this helps please vote me a fix ya
Jul 15, 2008 | Maytag Dryers
Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Samsung 7.3 Cu. Ft. Electric Dryer Logo
439 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
