Question about Bosch Nexxt 300 Series WFMC2201UC
Washing errored and now I cannot open it...HELP!
Washed a small but long rug (4 to 5' long 2' wide) on kid care cycle and 2/3 of the way in it error out. I tried to start the cycle over again becasue the door is locked and I cannot open it. But it error out again so I tried to but it on the delicate cycle and 10 mintues later it error and then I tried the hand wash cycle and again error. Then I tried to put it on the drain option and the motor just makes a low and subtle but consistent nosie like it is maybe stuck. If I could get into the machine I could see if it is part of the rug that is stuck but I cannot open it. Is there a way to open it even if there is water in it??? HELP!
  • kclphotograp Apr 27, 2010
    Its been turned off for hours and the door is still locked. Is it possible to release the lock??
  • kclphotograp Apr 28, 2010
    Problem Solver:
  • 10 Answers
Since I am the husband of this poster, and fixed the washer last night I thought I would post the details to help anyone else out with similar problems.
So, the issue was a clogged up drain line, and it needed to be cleaned. here is how to do it.
remove the circular access panel at the front lower right of the washer. To do it, pry up the side of the circle near the small hole, and at the same time twist the thing clocwise.
Next you see a big hand turnable plug. And also a white plastic zip tie hanging. If you pull the white zip tie downward, the door will release allowing you to get the stuff out, in our case a big rug. Also start unscrewing the plug slowly. Water will leak out, lots of it until the washer drains. In my case we have a floor drain underneath the washer, so I let it all go down there. You may need to get a small pan or something and dump it a few times.
Once the plug is removed, the clog was obvious. there is an impeller and screen leading out to the drain, it was completely clogged with pieces of the rug. I pulled it all out, put the plug screw back in and ran a cycle with no clothes in. It all went smoothly after that! good luck.
Posted on Apr 28, 2010
  • Xac135x Jan 05, 2011
    My front panel had three star head screws in the bottom . The cover panel slides down with a small force and is held together by tabs in slots after the screws are removed.. On The right side is the recessed cylinder hole.. The Plug takes considerable amounts of force to rotate. After The flood.of water and a little shop vac I found coins a fishing hook hair pins and a leggo. Everyone in my family is at fault. I did all this from my phone so I know the errors are everywhere. I Just wanted to thanks you for your posts
Wa52j8700a dirt remains bottom of washer
I would try to run an empty washer through about 4 or 5 rinse cycles and see it the machine will clean itself.
I would also carefully wipe it out after each complete cycle.
God bless your efforts.
Feb 29, 2016 | Washing Machines
Washed some dirty runners & 2 small rugs on Daily Wash; came up with error code 5E cleaned debris filter any idea where water hose mesh filter is?
Usually on the back where hoses are attached to it . inside hoses are screens . turn water off ,unscrew the hose and check , then put hose back on tight .
Feb 14, 2016 | Washing Machines
Kenmore he2t
fluff may have blocked the filter or jammed the drain pump. you need to check these
May 07, 2014 | Washing Machines
Error code f 50 stop and keep beeping
washed to small bathroom rugs.. on bulky items. low suds stopped at F code and can not get to rinse and drain and whole dial lit up. Tried removing one rug of 2 to lighten the load. still not working. Tried unplugging it and waiting. have had about 2 years. HELP.. read the directions.. it appears using bulky items was not wise. over did the agitation.. made too much suds?
Jul 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
F21 error message
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched.
If the hoses are not switched it could indicate a problem with the Electronic Control Board.
You can try to rest the washer by unplugging or flipping the breaker to the washer for 2-5 min.
Restore power to the washer and try running a short cycle.
This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jun 25, 2010 | Kenmore Elite 45986 Front Load Washer
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Washed a rug. Error code F21 came up when washer
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Rugs are notorious for losing fiber and holding loads of dirt. You may have something getting caught in the pump impeller and slowing it down. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
NOTE: The "SUDS" error can also commonly occur with the F21 error code as this is usually generated when air is sensed in the drainage system.
Oct 15, 2009 | Washing Machines
Whirlpool Duet won't stop draining
The F21 error on this line of washers is the machines way of saying the water took to long to drain from the tub. This could be a problem with one of the washer parts including the drain pump itself, how the drain hose enters the stand pipe, or maybe even something is stuck somewhere in the drain system and is preventing the water from flowing properly. Not quite an emergency, but it is an indication of a problem and a problem that can lead to something bigger if not looked into.
In talking with the customer, I found out the last load before all this started to indicate a problem was a rug from the house. Rugs can be troublesome to was as many of them used in laundry and bath rooms have rubber backings that can come loose when washed. When the backing comes loose, it can find it's way into the drain system and cause a problem, or the rug fibers can come loose and do the same thing. Figuring this was the problem, I explained to the customer how to get access to the drain pump by removing the three screws that hold the lower access panel in place. Here you will find the pump and the all important sump clean out, or as we like to call it, the coin catcher. Inside she found many fibers from the rub along with a few other things that found there way out of her kids pants pockets.
With the sump cleaned out, I asked her to try another load then to give me a call and let me know how everything worked out. A phone call a couple hours later told me the problem had been solved, and now this customer knows a bit more about her washer.
Many of the front load washers on the market have a user accessible clean out for just such an occurrence. Just be aware that if you open it up, any water that is still inside the tub will quickly be in your lap, so plan accordingly.
Feb 09, 2009 | Whirlpool GHW9100L Front Load Washer
Rugs won't dry
just air dry your rugs instead.
Jun 22, 2008 | Bosch Washing Machines
Bosch Nexxt 300 Series WFMC2201UC Logo
918 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
