Improving Vistas Performance
Recently purchased new dual core laptop. I have upgraded the ram to 2 gigs. I I am looking for info to improve Vistas performance. Thanks
  • longlanky Mar 24, 2008
    Can you make any recommendations as to what to tweak. The laptop will be used mainly for homework,email and websurfing. Thanks
  • 655 Answers
Navigate Control Panel Double click on Performance Information and Tools.
It will open the window which you want. There you can manage many more things as per your need. best of luck.
Thanks
Iqbal
Posted on Mar 24, 2008
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
I want to upgrade my memory on Acer Aspire 7551
why do you need more memory your machine wont work better
Jan 03, 2018 | Acer Aspire One PC Notebook
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
I have an ET1161-05- can it be upgraded to hold more memory and run faster?
Hi.
Yes, your computer came with 2 gig's of ram in the form of 2 1gig modules of ddr2 ram.
There are 4 slots for memory all together, and each slot can hold 2 gig memory chips in each one, for a total of 8 gig's of ram!
That would cause a serious performance improvement for you.
It also came with a 160 gb hard drive, so if you want to, you can get as larger drive as well.
As far as processors, a dual core, AMD Athlon 64 X2 5600+ Brisbane 2.9GHz 2 x 512KB L2 Cache Socket AM2 65W processor will fit in with absolutely no bios updates required, so all you would have to do is take the old processor out, put the new one in, and turn the computer on.
It will recognize the new processor automatically, and will work right away!
This will have a significant performance boost, possibly doubling the total speed of your computer.
I hope this helps you out, and have a good day !
May 26, 2011 | E-Machines eMachines Desktop PC
I have a laptop of compaq brand whose modle no is presario C700 in which intel celeron microprocessor is installed. 512 MB ram is installed i want to update it 4 improving its speed. i want to setup a...
I found the manual on the net that gives you instructions on replacing components if you're not sure how, it can be found here.
RAM upgrade
The Compaq Presario C700 uses DDR2 Laptop RAM as shown below.
slasher_x_11.jpg The motherboard of the Presario C700 has two RAM slots, one of them will be occupied by the 512MB RAM (running at 667MHz) module you have at present. This leaves one more that can accomodate a DDR2 667Mhz card of up to 1GB or you could get two 1GB DDR2 800MHz (the faster DDR2) cards and remove the 512 leaving you with a wopping 4GB of memory, that'll definately speed it up. Just remember the Presario C700 can only have up to 2GB of RAM so don't go higher than that or Windows will not boot for some reason.
Processor upgrade
The Presario C700 supports any Socket P, Core 2 Duo or Pentiun Dual Core chips. The fastest processor you can get is the Intel T8300 2.4GHz Core 2 Duo Processor with 3MB L2 cache and an 800MHz FSB
For a full list of compatible processors go to page 9 of the user manual found here.
Jan 11, 2011 | HP Computers & Internet
MT3705 Gateway, what motherboards will work with this laptop. I want to upgrade this laptop, so i want to get a motherboard able to really max out my ram but still use this chip set and everything else on...
You don't get different mainboards for laptops.....sorry. It's not like desktop pc's where pretty much any mainboard will fit. And even if you could, it's not really going to improve things, as you are using the same speed cpu. Your laptop has 2 ram slots. That's the most you will see on laptop mainboards.
Adding ram is probably the best bet. That laptop shipped with 1 gig of ram.....which is not enough for Vista. I bet it's quite slow. Vista wants 2 gig of ram to be happy, and 4 gig to really motor along. Laptop ram is cheap for that machine, so check it out. Ram is not expensive, and will give you an immediate, very noticeable improvement in performance.
Hope this helps. Post a comment and let me know how you make out
Sep 04, 2009 | Gateway Computers & Internet
Can I change RAM for COMPAQ- LAPTOP C301TU of 1.66 GHz; 256 MB; 60 GB to improve processing speed of Laptop. Date of purchase 24.12.06
upgrading your ram will not increase your processing speed. You can increase it but with your current setup my first recommendation would be to purchase a new computer, even if you upgrade you won't be happy in the near future with its performance.
Jul 12, 2009 | Computers & Internet
Midi audio plays fine but dumped audio tracks clip
Just a suggestion, I do not know how much RAM your new system has, but if it has less than 1 GIG then I would recommend a RAM upgrade.. My PC was running on 512K and my audio tracks were buffering, so I upgraded to 1 GIG and it seemed to fix the problems.. I am not familiar with the dual core systems, so it may be a technical issue You could contact the manufacturer from their site and look for support.. they may be more help than me
May 21, 2009 | Steinberg Nuendo 3 for PC
What more can i upgarde to improve performance ?
Just A Word Of Advice , Upgrading Laptop Parts Will Be Extremely Expensive ! your better off purchasing a new Laptop which meets your desired Specifications.
Are You happy Doing That ?
Aug 26, 2008 | Computers & Internet
Difference b/w Core to duo and daul core
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper.
they both are dual core CPUs.
I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
Jun 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
