Question about Maytag Performa PAV2200
IFB Bosch washing machine.
My washing machine otherwise eems to be working fine except that in the main wash cycle it does not get filled. On other programmes the filling, draining and spin cycles work absolutely fine. What could be the problem?
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
When switched on my washing machine doesnt fill with water
the obvious check that there is power to the machine
on normal wash cycle listern to see it you can hear a humming sound round about where the soap dispencer is, if not it could be a faulty electronic inlet valve , check to see if you have duel fill (ie hot and cold fill ) if you have try doing a cold water wash and see if you have the same problem if you have then check themostat, and then onto the more thechnical thing the programmer, the 1st couple of things you can check your self you will need an engineer to check the programmer and stat
NEVER OPEN THE MACHINE CASE WHILST STILL CONECTED TO THE MAIN POWER SUPPLY
Jan 16, 2010 | Zanussi FJ1254W Front Load Washer
Washing Machines Logo
861 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
