Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Door will not open door light just flashing on and off
The washing machine has no water in but it wonrt let you do anything my washing machine is a hotpoint aquarius washer dryer wd420 1200 spin only reason why iam asking is i live in france and i dont speak frence and if i get a enginer they try to flog you anything but never fix it right or do somthing to make somthing esle go wrong later any way look forwards to hearing from you thanks ian
Washer not spining mini load button flashing on/of buton flashing
Posted on May 05, 2010
Problem with AWO3561 wash machine red door light flashing
there is a valve for the door lock if this goes it thinks the door is open and shuts down thinking the door has been opened if the feed pipe become blocked the water pressure sends air pressure to the switch when water is added. spin/drain setting it don't use this sensor switch, but on filling up it will. its usual down to a blocked pipe , or a leak in the line. sometimes it can be the switch, the pipe is located at the bottom around 2 inches from the bottom and the feed wire goes to a sensor , take the pipe off and blow down it best to have some water in the bottom of the drum, so suck and blow on the pipe to loosen anything blocking the pipe. switch don't blow or suck on this as it can damage the sensor. if the sensor is at fault you can only replace it as the valve inside for the switch if you use anything it will pierce the valve , hope this helps you.
Jun 24, 2017 | Washing Machines
My zanussi zwg 6141p washing machine is calling water at start of cycle but is not going into drawer to swill out detergent , is also stopping half way with the green light on the start button flashin
Some appliances malfunction can be displayed in hexadecimal or in binary code.
So your device is defective and shows you what's wrong. You have to count how many times flashes red light and how many times flashes green light. Red light shows the first error number and green light the second error number.
For example: you forgot to close the door and you started washing machine. After some time (timeout) will generate an alarm. Four times will flash red light and once the green light which means error code " E41 " or "Open door"
" E20 " means "No drain water"
" E10 " means "No fill up water"
Dado
Sep 08, 2014 | Zanussi Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
Hotpoint door not locking
i think the problem from what you saying come from { a water level swith} because it contol also the door from opening when the water is still in the drum so it may need to change from the begining >
thanks
Jul 09, 2009 | Hotpoint WMA33 Front Load Washer
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Zj1217 door not opening
you need to clean your pump there is a safety feature in the washer that will not allow it to open if there is water in the machine if you open the pump be sure to have plenty of towels
Dec 26, 2008 | Zanussi ZJ1217 Front Load Washer
Start light flashing
start light on and no other action could mean that the door catch has gone faulty, test accordingly and replace if needed, no wash cycle will work if this item is faulty, the waste outlet pump may be the only part that will work on some models, this is a safety feature hope i have helped if so please rate me, work safe unplug when testing
Sep 21, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
296 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
