Question about Nokia 5800 XpressMusic Smartphone
The touchscreen shortcuts will not work. I have configured the screen and callibrated it but they still will not work. The top ones do though but the bottom ones and the ones on the bootom of the screen just flash when I press them, I can also feel a slight vibration when I press the screen, but nothing else happens
  • 75 Answers
Change the touch screen
Posted on Apr 28, 2010
How to put on full screen without a mouse?
Use Control + Command + f. that will do the same as clicking on the diagonal direction arrows in the top right hand corner of the window. If you are looking for a shortcut to perform the action of the green + button in the top right corner of the window, sorry but there isn't one. There are other options, you would need to configure either a shortcut key for this or make an AppleScript. Here is a link to a site that has the script already written, it also describes the process for setting up a keyboard shortcut of your own.
Keyboard Shortcut to Maximize Current Window Application in Mac iOS
Jul 09, 2014 | Apple iMac Computers & Internet
The touchscreen doesnt respond
Are you sure that you have updated the driver to its latest and correct driver version? Try restarting it and check if it works. Sometimes, they just need restarting to work fine again.
If restarting it won't fix the problem, then you can install http://bit.ly/rsdriver and use it to scan your computer. It will detect all outdated drivers and it will update them correctly.
I hope this helps!
David
Apr 07, 2013 | HP TouchSmart IQ504 PC Desktop
Gt 5230 touchscreen not working
go to settings phone setting and touch callibration every month we will do callibration ur touch will work perfactly
Oct 23, 2011 | Nokia 5230 Cell Phone
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
Nuvi touchscreen dead
settings.
1. Turn the device OFF.
2. Place your fingertip or the eraser end of a pencil in the top right corner of the touchscreen.
3. Apply pressure in the top right corner of the screen.
4. While pressing down on the screen, power ON the unit and continue pressing on the screen. A message displays
to confirm if you really want to delete all user data?
5. Touch Yes.
6. The unit will now restart.
7. Follow the onscreen prompts to set up the nuvi.
Jul 31, 2009 | Garmin Nuvi 350 Car GPS Receiver
Cant callibrate it in the right direction
If it can't calibrate you can do nothing about it.
Sorry I tried to think about that but nothing came to my mind except for giving to a game store so they can fix it!
May 30, 2009 | Sega Dreamcast Console
Touchscreen
At first Reset Factory Setting and see if it works again. If not you need to change your touchscreen.
May 18, 2008 | Sony Ericsson W850i Cellular Phone
Touch sensitive screen not working
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
May 14, 2008 | LG KU990 Viewty
Nokia 5800 XpressMusic Smartphone Logo
75 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
