Question about Zebra Z4Mplus Label Printer
My machine keeps reading
I added the ribon to the machine and now it reads ERROR CONDITION PAPER OUT
    Scholar:
  • 97 Answers
Sounds like you may have inadvertenly loaded the ribbon underneath the label sensor, blocking it, and making the printer think it's out of labels. Check the ribbon path to make sure it's loaded above the label sensor.
Hope that helps !
Posted on Apr 27, 2010
Anytime she goes to print a badge the ribbon breaks. It's the correct ribon. She's put in a new ribon and the same thing happens.
When the ribbon keeps breaking on fargo DTC300 or any similar models (the ones that share similar mechanics) three steps are to be taken.
1- Verify, clean, calibrate or replace the ribbon sensor (maybe you'll see an error like "Panel Searching" that means " the ribbon sensor can't read the ribbon panels normally).
2- Clean the "card path" (the feed and platen rollers) for dust dirt and debris using the manufacturer's cleaning kit (or a clean
lint-free cloth with isopropyl alcohol) and the "clean printer" option.
3- Clean the inside and outside of the printer (pay attention to the printhead) with dust-off, lint-free cloth, isipropyl alcohol and enjoy.
Or, for more advanced ts take it to a certified tech!
Mar 02, 2011 | Fargo DTC-300 Thermal Card Printer
Reads "machine error af"
There is something wrong with the document feeder. Check if there are no pieces of paper stuck somewhere, and that any sensors are not stuck (sensors are usually small plastic pieces, that are lifted up when a sheet of paper moves below it).
Nov 07, 2009 | Brother MFC 9180 All-In-One Laser Printer
I cannot receive faxes, but can send them.
Courtesy www.brokenfax.com :
Sharp ram clear (most models with LCD displays)
Press function 9 * 8 # 7 then # or * until display reads memory clear, then press start. Best of luck and hope this solves your problem.
Greg
Jul 24, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Error Code #380
check in back side of printer there should be small paper jam check it.
Jul 13, 2009 | OKI C5100n Laser Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Machine reads "document jammed"
its the problem of the rollers which pulls the papers they r worn out.I've seen this before repairing computers and asked about fax machines while I am there. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Printer will not feed/accept paper.
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
May 25, 2008 | Epson Stylus C48 InkJet Printer
Jammed paper message
I get a Jammed paper message on the read out, I have cleaned out all the paper and pressed stop/cancel button but it still keeps saying that there is a paper jammed in it.
May 04, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Canon laser class 2060p super g3 fax machine
The error keeps flashing and the machine will not work. The error reads, "check cover/cart". We put the cartridge in and out about 10 times and the same error message keeps flashing. the fax machine is still not working. Help!
Apr 24, 2007 | Canon LaserClass 2060P Plain Paper Fax
Zebra Z4Mplus Label Printer Logo
706 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
