Question about Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
There appears to be a large black smear that is faintly observable in the background, on the right side of the screen. It is very apparent when the picture on the screen is light in color or when the satellite is turned off, leaving a grayish white screen.
  • 50 Answers
This appears to be an LCD if the model is right. If so then i hope u have extended warranty because what you have is a bad screen. something has caused the layers to separate, either a cleaning solution you used of just a plain unlucky. but to get rid of it replace the LCD Panel which is not cheap. Good luck. PS dont use any kind of cleaning solution it ruins the screens
Posted on Apr 27, 2010
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
The screen is way too large. How do I make it
Right click on the background and select properties and select appearance and change the resolution to a lower setting... if its your screen its self their should be an auto function that will adjust it to the right setting by the monitor buttons
Aug 06, 2009 | Acer X193W LCD Monitor
Esp3 printer, has new cartriges, printing very fient
Have you tried the maintenance tool - if you open the kodak printer status monitor in your taskbar (next to the clock); at the top right hand side you will see an icon showing crossed hammer and spanner, click on this and run the tools from top down (dont need to do the test page).
If that doesnt work you could try this:-
my new esp3 printer (replaced due to not printing black) came with a suppliment document for action if no black or faint print appears!!:
verify paper is loaded into paper tray then press and hold the Cancel and Copy/Resume buttons simultaneously until the On/Off light flashes -apparently this fixes the no black/faint issue.
hope this helps
Jun 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
C-7250 HP all in one appears to have a stopped up printer head?
Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK Inkypete
Apr 23, 2009 | HP Photosmart C7250 All-In-One Thermal...
My hp compaq nx9010 notebook is no longer displaying the color black on the Windows xp start up page or on some of my powerpoints and videos. The color black is replaced by a redish color.
It seems that someone changed the desktop background color. point the mouse somewhere in the middle of the desktop, (away from any icons) and right click the mouse, a menu will appear with several options. The bottom one says properties. Click that. Once done another (more advanced) menu will appear with several tabs at the top. Click on the second to last tab, labled, "Appearance". Once in this tab. Toward the bottom right side of this screen you will see 2 buttons one atop another labled, "Effects", (on top), and, "Advanced", (below). Click the advanced button. A new window will pop up with the first option being desktop in a drop-down menu. To it's immediate right you will see "color 1" with a drop-down menu directly below it. That is where you will select the new background, (desktop) color. Once you have selected the new color, click OK, then apply on the remaining screen, then OK once the color is set.
Apr 16, 2009 | HP Compaq nx9010
Today there appeared smears on the display
My grandson suggested I unplug the computer from the wall and leave it out for a while. i did, and it worked!
Mar 20, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Black blob appears on display screen and the background is white
This usually means that the liquid crystal has been broken in that section. Usually caused by something poking or pressing on that section of the screen. The only solution is to have it repaired or replace the camera. I'd get an estimate from an authorized repair shop or Samsung directly, and then weigh the options against buying a new camera, buying a working used one, or paying for the repair.
Dec 30, 2008 | Samsung Digimax S730 Digital Camera
Vertical bars both sides of screen visable with white background
do thy get lighter going from left to right? prob bad scan filter in hv. need tech unless your very handy.
Dec 05, 2008 | Sony KP-53HS10 TV
Faint Black Line down the middle of TV
Sounds like it could be pixel problems or board problems, this depend on the location. Most are mostly to the left or right, or going across the set to the upper or more to the lower side. For more info visit ctechnicians.com
Jan 06, 2008 | Sharp LC-37D7U 37 in. HDTV LCD Television
Sony BRAVIA KDL-40S2400 40 in. LCD HDTV Logo
200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
