Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
On a Kenmore dishwasher model#66513779K600--the clean light blinks 7times.The tech sheet isn,t with the dishwasher.The dishwasher does nothing--pump works on cancel. Thanks. Rene
  • Rene Matz Apr 29, 2010
    Ended up ordering a motor/sump assembly.Thanks again for your help. Rene
    Brigadier General:
  • 3,513 Answers
Thanks for writing to Fixya.com.
This is a common specially with the Kenmore models dishwashers. The reason is to water supply temperatures being too low when filling. There are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval. This time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Apr 27, 2010
Why is my kenmore dishwasher blinking clean?
It's trying to tell you that there is something wrong with your dishwasher. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller. Usually there is a tech-data sheet located on the other side of the toe-kick panel which will explain the meaning of the varius blink codes, but you might still need to call a technician to fix the problem. Don't forget to put that tech data sheet back so he can find it and use it to fix your dishwasher!
Jul 06, 2014 | Kenmore 24 in. 15932 Built-in Dishwasher
The clean light on kenmore dishwasher elite keeps blinking and will not stop
That blinking light is trying to tell you that there is something wrong with your dishwasher. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches. Usually there is a tech-data sheet located on the other side of the toe-kick panel which will explain the meaning of the varius blink codes, but you might still need to call a technician to fix the problem. Don't forget to put that tech data sheet back so he can find it and use it to fix your dishwasher!
Dec 16, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a kenmore ultra wash and it wont turn on, the "clean" light is flashing and thatis all it will do
If this is a Whirlpool manufactured dishwasher, the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat related problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccurring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel.
If you still need assistance, please post back with your MODEL NUMBER and let me know
Apr 29, 2011 | Kenmore Dishwashers
Clean light flashes,will not start
On Whirlpool manufactured dishwashers (such as Kenmore), the blinking clean light is an interruption in the dishwasher program that usually indicates a component problem or program malfunction. If a component is defective, it is commonly attributed to the heating cycle or thermostat problem. To rule out component failure, or program error, the following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
If you still need assistance, please post back with your MODEL NUMBER and let me know.
Apr 20, 2011 | Kenmore 24 in. 17463 Built-in Dishwasher
Kenmore dishwasher model #665.17034401 --- Clean light blinks
The blinking clean light is an interruption in the dishwasher program that indicates a component malfunction, or it can be a result of a momentary program glitch. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
May 07, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
The clean light on my Kenmore Elite blinks and the washer will not do anything else--how do I reset the machine>
Apr 12, 2010 | Kenmore 24 in. 15142 Built-in Dishwasher
The clean light is blinking, and the cycle won't
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or a simple program glitch. The following link explains how you may be able to clear the blinking clean light problem:
I hope this helps you solve your problem.
Jan 06, 2010 | Dishwashers
Kenmore DW blinking clean light 7 times, pausing, blinking 7
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Oct 11, 2009 | Dishwashers
Kenmore 24in 13832k clean light blinking and not
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
Sep 02, 2009 | Dishwashers
Clean green light blinks. It will not start a
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
If you have any questions, please let me know. I hope this fixes your problem.
Jul 12, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
