Question about Cell Phones
Hello I have a Sciphone i9+++ and the memory status says usage 0/100; uses space 0k; and free space 0 bytes. Problem is I have a 4g micro sd memory card installed. What must I do to send and rec mms? Thank you for any reply.
  • sinclair70 Apr 30, 2010
    I have tried that already and what I am getting is memory status usage 0/100; used space 0k and free space 0 bytes. This is when I go into mms status, when I go to the memory card through documents it reads the ring tones and photos I have but I can not send or rec photos of any kind. Someone please help!!!
  • 75 Answers
First recover your data then format it !
Posted on Apr 28, 2010
My tablet keeps giving me error message. Insuficcant space on tablet to download apps
This means the internal memory is full and the only way to add apps is to uninstall other apps that you have installed. Check to see if you have apps you no longer use and uninstall them.
Jan 02, 2017 | Tablets & eReaders
Mirco SD card shows free space 0 bytes and used space 0 bytes
Click on the drive and then in windows select tools then folder options, then view and select or unselect hidden files or folders, plus hide protected files.
This should show all files on the card.
The only other thing I can think of is that the camera uses a different format to Windows. So it can't read the card.
Jun 07, 2017 | SanDisk Electronics - Others
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 10, 2011 | SanDisk 2GB microSD Memory Card
32gb SD card is showing 0 bytes used space and 0 bytes free space
Try formatting the card and be sure the locking switch is in the off position.
Sep 14, 2011 | Transcend (589307) Media
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Nov 26, 2010 | Transcend (589307) Media
My new SciPhone i68 does not recognize the memory card.
when i put my micro sd into my sci phone and then go to documents it is not there it says just the phone memory. how do i format the memory card to my phone or even to get it to work ?
Feb 22, 2010 | Computers & Internet
I just recieved my new Cect I9 phone, Not enough memory
Has anyone answered you on this issue? I have the same problem.
Feb 10, 2010 | Cell Phones
I recently purchased a sciphone i9+++ and it says 16GB but seems
The back cover on mine states '32gb'. that is just smoke and mirrors!
The amount of memory on these depends on the micro sd memory on the inside. My phone came with a 2gb card and I just upgraded to a 8gb and it works fine.
Your issue could be one of two things...
1) you don't have a micro sd card installed or minimal one; or
2) you have lots of memory via your sd card but you are trying to save the items to the phone memory rather than the sd card.
If #2, mine shows as a removeable drive on my computer. you can right click and select properties to determine the size... if it matches the card you have then that should be the one (depending on what other 'things' you may have connected to your computer).
Cheers
Oct 08, 2009 | Dual Electronics CECT P168 Cellular Phone
2gb sd card but available only 1gb
levyveress,
Well you have a 1GB SD card, there are roughly 1,073,741,824 bytes max per gig. They vary slightly from USB flash drives it total bytes, but the number should be 1,930 (or something close) MB for the 2Gig SD card, bring it back it may have been mislabeled on the packaging.
randy320sgi
Jan 17, 2009 | SanDisk 2GB microSD Memory Card
Cell Phones Logo
217 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
