Question about Brother ML-300 Typewriter
My typewriter works just fine, but the typewriter doesnt type the correct letter that corresponds with the button. Power is on and ink is good but A isnt A and B isnt B.....
    President:
  • 405 Answers
Its the daisy wheel that is defective. You will need the replace the daisy wheel for a new one.
Posted on Apr 28, 2010
Is there an auto correction feature
The key to the right of the spacebar with the "X" printed on it is the correction button. You just place the carrier on the character to the right of the wrong one and hit the corr. button. The carrier should automatically back up and and remove the incorrect character and if you hold the key down it will continue to back up and remove characters. then you just type in the right one(s). Of course you have to have good "correctable" ribbon and correction tape cartridges installed. If the tapes are old you may have to advance them by typing and correcting or by manually advancing them before they will work. If the correction doesn't remove all the ink from the paper you may have a bad ribbon and/or correction tape.
Sep 17, 2015 | IBM Wheelwriter 3500 By Lexmark Electric...
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
The typeball will only type one letter, it doesnt seem to be able to spin to the correct letter.
You listed this this as a wheelwriter thentalk about a type ball. Is it a WW or a selectric?
DickyO
Mar 29, 2010 | Lexmark Wheelwriter 15 Series II...
IBM wheelwriter types wrong letters
Try holding the code key and pressing the "L". If that dosen't do it remove the batteries turn it off wait a minite and restart this will put everything at default setting and clear the memory. If you still have the problem Press code "L" hold down the "L" type 001 to set the keyboard to U.S. If this works you need a keyboard for a permanent repair. For a keyboard contact Geo. Beyers Co.
@ 800-392-8085.
DickyO
Dec 14, 2009 | IBM Wheelwriter 30 Typewriter
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
HELP..BROTHER DAISY WHEEL TYPING RANDOM LETTERS AND SYMBOLS
Press the Code button and the Q/Reset button at the same time and the wheel will spin and go back to the correct place.
Feb 06, 2009 | Brother SX-4000 Typewriter
Typed letter doesn't correspond with the letter stroked on the keyboard
Printwheel has a bent spoke causing not to turn smoothly.LAWRENCE
May 11, 2008 | Brother SX-4000 Typewriter
Brother ML-300 Typewriter Logo
204 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
