Question about Maytag Kitchen Ranges
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
  • Beth Feb 10, 2013
    Did you ever figure out what the issue was? We have the exact same problem!
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
lilkadoc@hotmail.com
Posted on Dec 31, 2010
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
Jan 03, 2015 | Maytag Gemini 30" Self-Cleaning...
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
I have a Maytag Performa gas stove. The burners on top work fine. The oven part glows when I turn it on, but it does not heat up. Is there a pilot light that I can light, or is this a completely...
The problem with the oven not lighting believe it or not is going to be that the igniter is weak and not drawing the correct amount of power to allow the gas to flow.I know it would seem since the igniter comes on that it could not be the problem yet since it comes on to me a oven technician with 30 years experience the igniter is exactly what it is.
GENE
Sep 25, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
We have a maytag performa electric stove, probabley about 6 years old, and last time we did the self clean on the oven we had a lot of stains that ran down between the inside and outside door panel. This,...
Can anyone please give me the serial number and product number to a 6 year old Maytag Performa glass top stove?? I just broke the ceramic top and need to replace it but don't have a serial number.
Thanks
Liliana.
Dec 12, 2010 | Maytag PER5710 Performa Electric Kitchen...
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Stove control panel not working
You do not have a fuse or overload button on a Maytag cook-top. If you heard a pop, it was the touch pad on your control board blowing out.
Oct 22, 2009 | Kitchen Ranges
Maytag performa model per4311acw
The oven's element may be defective. Take a look at the heating element and look to see if there are any unusual 'marks' on the element.
It is a simple fix.
Unplug the stove, unscrew the screws holding the element to the back of the stove, gently pull the element a few inches towards you, pop off the connectors, take the element out and take with you to the store. It is a good idea to take the model nukber with yoy when you go to the store.
To replace, just reverse the steps above.
Sep 07, 2009 | Maytag PER5710 Performa Electric Kitchen...
Where can i find a replace glass top for a maytag performa stove
Hi, get ma a model # and I can get you part # and location of a glass.
Vic
Jun 06, 2009 | Cooktops
I have a Maytag Performa free standing stove/oven. The range top works well, but the oven will not work. When you program the oven to come on, the tempeture starts at 100 then quickly goes to programmed...
I am assuming that element does not come on at all...
A good place to start is the temperature probe . If it is Reading too high, its signal the control board that it does not need to heat.
Alternately the control board may not be acting properly.
Jul 28, 2008 | Maytag Kitchen Ranges
Kitchen Ranges Logo
460 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
