My sanyo CE42FD90-B flat screen tv turned itself off and the led light is now flashing very fast at least 2 times per second and we cannot turn tv back on
  • kmaggottsk Apr 27, 2010
    so basically what your saying is i need to get an expert to look at it as this is an electrical fault of some sort?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Apr 27, 2010
  • Rylee Smith
    Rylee Smith Apr 27, 2010
    Yes you are right or may be if you want to do the repair and have knowledge of internal circuitry of the TV then you can do it yourself.
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
My tv isnt coming on. first it was a flashing blue light. Manual said it was the fan, checked and it's fine, now no led and no screen. Fan is still running though...
same TV same problem!! Only my LED is still on and flashing. The screen never actually turns on. I'm not sure if you tried to turn it off but I did and about 5 seconds later it will turn itself back on. Again, manual says it's the fan.. I popped the back open checked it and cleaned it but still nothing. Maybe trying to reboot but I left it on for 2 days straight and nothing came back to life. I just took it to a repair shop this weekend so I guess we will see! I will post any answer they give me!
Dec 01, 2015 | Toshiba Cinema 65UL610U 65" 3D 1080p...
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Jun 03, 2009 | Sharp LC-26D43U Television
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
Sharp 42
You either have broken power board or main board. Power board - blinking 2 per second, main board 3 times per second. In an case it has to be fixed by a technician.
Sep 18, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos
you can try resetting the tv by
1. unplugging it
2. pressing channel down and volume up buttons at the same time while plugging tv back in
3. if you here a click, the tv has been reset
May 12, 2008 | Sharp LC-46D64U 46 in. LCD HDTV
Aquos LC37D40U Blinking light and won't turn on
The power light is an error code that tells me exactly what is wrong with the TV. Count how many times the POWER led flashes per second? (Dont worry about the OPC led)
1x per second (constant steady blink) = bad inverters/lamps
2x per second = bad power supply
3x per second = bad main board
If its 1x per second, try doing the factory initialization to get the TV back on to confirm a bad lamp/inverter.
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go.
Once the TV turns on, take a look at the screen. Does it flicker then shut off? Or do you hear a buzzing noise from the right edge of the TV? If so, then you have bad inverters or lamps. Once youre done, unplug the tv to get it out of the service menu.
If it is 2x per second or 3x per second, then those boards are just bad and they need to be replaced. There isnt anything you can do right now to fix it.
Mar 27, 2008 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
