The laptop is not working and when it is turned on it has a beeping noise
  • 520 Answers
What exactly happens.
is there anything at all on screen
how many beeps are there
beeps indicate hardware malfunction or generally not connected properly.
remove hard drive and replace properly.
remove mem,check for dust,debris , clean and replace.
could be a lot of things but these are the most likely.if no joy let me know
Posted on Mar 24, 2008
  • 655 Answers
There are different types of beep called POST beeps.
This informs that what the problem is on booting the system.
As per your concern I think it will be along beep 3-4 seconds long, and continued again and again, if this is your case then your RAM might be faulty or it is not connected properly.
To fixed the problem, re-connect your RAM and try,you should also try to boot with another RAM.
Thanks
Iqbal
My laptop makes loud beeping noise and screen comes up all fuzzy & crazy
sounds like hard drive is bad, replace with new or buy new computer
Jan 09, 2013 | Acer Aspire Computers & Internet
Load beep when i plug charger into my gateway m675
I have two of the Gateway units and both do and did beep if on and power cord inserted---normal.
Dec 01, 2012 | Gateway 17.1"lcd M675prr Notebook-laptop...
What's your problem?toshiba satellite l555 s7916 wil not boot
Try Resetting the CMOS on your Motherboard.
Turn off the Laptop and unplug it
Remove the battery
undo the RAM cover
Remove the RAM
plug the laptop into the power
Turn the PC on and listen for some beeping noises
If you hear the beeping noises turn the laptop back off
Unplug the charger
Replace the RAM into the RAM slots
Replace the the battery
Plug in the laptop and power it up.
if you get video output, that's Great, if not, it's possible that you have a faulty screen
Oct 05, 2012 | Toshiba Satellite L555-S7916 Notebook
Loud beeping noise when trying to turn laptop on
beep is a hardware error
check yr hardware
expsly ram, keyboard and c mos bat3
tq
Mar 23, 2011 | HP Computers & Internet
When i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this.
Hi there, I am also facing same problem with my Dell Inspiron mini 1012, when i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this. S Bhat, India
Nov 01, 2010 | Computers & Internet
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
Nov 07, 2009 | HP Pavilion dv9000z Notebook
Spilt a drink
I don't know if I can solve this here. But the beeping noise is your pc trying to tell you what is wrong with it. Somewhere there are pc beep codes. http://www.pcstats.com/articleview.cfm?articleID=1223 If these can't help you just put "computer beep codes" into google. Here they are:
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Dec 08, 2008 | Compaq Presario 5000 PC Desktop
Loud beeping noise
Hello!
The system memory is damage. you can replace the memory.
before you replace you can test the memory or remove the memory and clean it. after cleaning insert it back. some memory work with this solution. hope it work.
melnavz
Mar 18, 2008 | Acer TravelMate 2480 Notebook
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
