Question about Panasonic PT-52LCX65 44" HDTV
I have the replacement lamp and can put it in, but I do not have the remote to reset it with. How can I reset it without the remote?
  • nwyrk4me Apr 27, 2010
    I was afraid of that!! Thank you for your help
  • 10,594 Answers
Panasonic tv remote is necessary to reset lamp timer, I'm afraid, there is no other way to perform lamp timer reset function. TV Remote can be obtained from friends/ neighbors just to complete this task.
Press and hold Volume down button on tv front and press and hold play/ split button on tv remote at same time for 5-6 seconds to reset lamp timer.
Hope this info will help you.
Thanks.
Posted on Apr 27, 2010
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
I have a nec vt570 projector and it has gone into bypass mode because I let the lamp go to long. I've replaced the lamp but can't reset the hour meter.Is there any way to reset without the remote
Switch on the projector in standby mode.
press the HOLD button on the remote for 10 secs.
the projector will come out of protection and you are good to go!
ensure that u replace a new lamp!
This can be done only with the NEC remote!
Jun 04, 2015 | NEC Office Equipment & Supplies
How do you reset the lamp clock on Panasonic model number PT-61LCX35 without an original remote?
We regret to inform you the original remote is necessary to reset the lamp hour meter. We recommend you use the below link to obtain the correct remote control for the TV. The remote part number is EUR7627Z70.
Parts Ordering
Mar 17, 2014 | Panasonic Televison & Video
How do i remove the black box on my screen
don't have the original remote control, I used the time warner control, I just reprogramed to control my tv without the cable box, I put the volume all the way up in the tv, then down to zero, and at the same time I hold the 0 key in the remote control, after that the screen said lamp has been reset to zero, I repeated this step because a lamp red light stayed on, after this only the power green light only stays, when installing the new lamp make sure is all the way in, you can use the white out to mark exactly where you have to push or put in the new lamp, it may not been all the way in, hope this help someone !!
Jan 18, 2012 | Panasonic PT-50LC13 50" Rear Projection...
How to reset lamp timer without remote
you cant, when you remove and replace the lamp cover the tv will come on and ask if you changed the lamp. you need to press enter on the remote (not the tv) to reset the counter. go buy a universal remote and program it to your tv then use that. make sure the remote you buy has an enter button. most should, but you never know.
Jul 06, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
How to reset the lamp of NEC MT1050NL projector without the remote
You can do this via the buttons on the case...just navigate via the menu and find the menu for lamp resetting. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Oct 14, 2007 | Sharp Projector lamp Projector Lamp
Removing the "lamp needs replacing" warning message
Hi guys
Firstly you need the remote to reset the lamp timer.
Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
Jul 31, 2007 | Sony VPL-EX1 Multimedia Projector
Panasonic PT-52LCX65 44" HDTV Logo
182 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
