Question about Passport 8500 Radar Detector
Getting false laser readings, any adjustments?
I'm getting false laser readings on my Passport 8500, any adjustments?
  • 4 Answers
This is fixable as described in other threads here. This is annoying and seems to be random, though it also does it sometimes when the wipers are turned on or I use the windshield sprayer. 2 minutes with a smal Philips screw driver and a Q-tip will fix it. I just did mine and it works great now.
Unscrew the three screws, pop the three components apart (it really is a no-brainer since they only fit back together ONE WAY, so don't be nervous. There is not anything that is going to fall apart or spring into a hundred pieces in there.
I used canned air to blow everything out and just used the Q-tip on the front window and the parts that looked like the detector window internally... I didn't bother swabbing all of the board.
IT WORKS! GREAT FIX!!!!! DO IT!! NO MORE FALSE LASER ALARM WHILE ACCELERATING and randomly.
Posted on Aug 27, 2010
I have just started getting the same constant false laser alerts. It seems to be as I accelerate. Strange. I called Escort and they asked if it does the same in another vehicle. If it acts O/K in another car, is there any new electrical equipment in the car where it does happen?
They (Escort) suggest returning to them for repair/tuneup. $59 . Seems to me that this is an issue that they are aware of but want payment to fix !
Posted on Jul 29, 2010
  • josh Aug 26, 2010
    yes i have had mine for about 6 years now, it used to work great i would die by it but now adays no way it does the same false laser reading to me too as i accelerate. i sent it in for repairs like 3yrs ago and they wanted $49 for it worked well for a while i got a speeding ticket while i was useing it too.
  • 93 Answers
There really is no way to adjust it. Maybe they arnt false maybe the cops are just hiding
Posted on Apr 27, 2010
Goes off frequently with no radar nearby
False alarms are common with most radar detectors. You may need to adjust your detector's settings to compensate for the interference that sets off the alarm. Check your user's manual for instructions on using the menu.
Jan 04, 2011 | Passport 8500 Radar Detector
Passport 8500 escort
Hello!!
Hold all three buttons down and reset it.hope it fixes the problem!!
Regards
Smilemaker
Jul 19, 2008 | Passport 8500 Radar Detector
I also have a 8500 passport that flashes laser and will go off
Does this happen in the city or does it happen when you are out in the middle of nowhere? I have seen laser detectors that are falsely triggered by various lighting devices that contain wavelengths of light similar to those used in police laser.
If this is annoying and you dont want to hear it, you can locate the receiver element that detects the laser signal and cover it up with a piece of black electrical tape. That should stop whatever is causing your problem unless there is something actually broken inside the unit.
Thanks,
r
Aug 21, 2009 | Passport 8500 Radar Detector
False Laser Detected/Other
IF this happens when you first get into the hot car, the problem is likely to be that the electronics in the unit are too hot. If the problem goes away after the car cools off inside (assuming you have AC), then your unit has just become overheated.
Aug 15, 2009 | Passport 8500 Radar Detector
Laser goes off when i am driving in area were there is no buildings or police cars also goes to k ban what is this problem
A lot of the time this is caused by a somewhat flaky power connection to the radar detector, or may be caused by excessive electrical system noise created by your car's alternator. The cigarette lighter socket itself my be the problem due to oxidation within the socket. Do you get false laser alerts when you rev your car's engine to certain RPM's? Do you get either laser or radar falses if you jiggle the radar detector's power cord or slightly move it plug in the cigarette lighter socket? If yes, to either, then installing a hardwire power kit may solve the problem. Jump over to radardetector.net and describe the problems you are having with your radar detector. Most likely they will help you to track down the source of the problem.
Jun 25, 2009 | Passport 8500 Radar Detector
Getting false alarm from laser. Laser alarm keeps
If the laser continuously falses even with the car's ignition turned off, then your radar detector has an internal electronics problem. If your radar detector frequently or nearly continuously falses for laser while you are driving even in the middle of nowhere, then most likely the cause of the problem is either poor power and ground connections or electrical noise within your vehicle's electrical system. Jump over to radardetector.net for help in resolving these issues.
Mar 15, 2009 | Passport 8500 X50 Radar Detector
Laser warning - Multiple false alerts
Although the detector could have internal problems, it is possible that it is coming from a real source.
A route I took between home and business triggered mine along the same stretch every time I passed it and after looking a a map and comparing it with the stretch I drove, I found that the Marine airbase at Miramar California was visible (line-of-sight) between two mountains only along that stretch.
Note if the falsing happens at about the same point each time.
I just learned to ignore the laser alarm if it triggered during that 1-2 mile 'window.'
Jul 11, 2008 | Passport 8500 Radar Detector
8500 Alerts for no aparent reason
Got to the bottom of my false alarming situation. I finally called Escort and discussed the behavior with the technician who immediately concluded the antenna was failling and needed a repair. $30 worth of shipping and about a week later I got my repaired unit back and it works perfectly. Not sure the root cause but I am going to treat it as gently as possible and hope it keeps working, I sure like it better than the V1.
Dec 05, 2007 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
2,642 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
