Two identical capacitors connected in parallel what will be enrgy
If a fully charged capacitor connected in parallel with zero charged capacitor then what will be the energy before and after connection?
two capacitors are identical with same ratings.
  • 379 Answers
Theoritcally, the energy (in Joules) will be exactly the same as all you are doing is effectively doubling the capacitance.
In practical terms, the energy will be very slightly less after connecting them as the charge on the charged capacitor has to be equally distrbuted across itself and the uncharged one, by the flow of electrons via the electrical connection between them. This connection will have a finite resistance (allbeit very low if the connection is not very long), therefore some energy will be dispersed as heat as a result of electrons flowing through this resistance (Amps squared times the resistance times the time it takes for the charge to equally distribute - Joules heating effect & Ohms law).
Posted on Apr 27, 2010
How many wires on the capacitor & which color wire goes into which slot of the pull chain switch?
capacitors are of a construction of two plates separated by an insulating material
the charge is the differentiating charges of the plates + charge trying to neutralize the - charge of the other plate
so which ever wire is not important when connecting a 2 wire capacitor as either wire will put + charges on one plate and the other wire will put - charges on the other plate
when the switch is activated, the sudden discharge as the plates cancel each other out produces a surge of power that start
s the motor spinning
In some instances, capacitors are used to absorb electrical energy that causes static in other electrical items like radios , tv etc
again the wire connections is immaterial as it acts like I stated by placing + and - charges on different plates and discharging when there is a cycle change eliminating the lack of power flow when the cycle changes in the AC current
Apr 30, 2015 | Dryers
Where is the capacitor
The start capacitor will look like the attached image and will be on the mains power side of the wiring connected across the compressor motor. The location of this capacitor will be somewhere within the compressor tower unit but could be in a separate compartment with other electrical items such as the fuse block or connection terminals.
When this part is no longer working, the motor will not start its rotation even though you will measure power to the motor. This part is a common failure and can be easily replaced, but only once the mains power is fully disconnected. Capacitors store energy so you should use caution around the contacts and wiring to avoid a jolt of DC.
I hope this fix is helpful to you.
Feb 27, 2015 | Heating & Cooling
How is NewNow Bamboo VI 15600mAh external battery ?
I think you have an extra zero in that mAh rating...Make sure to fully charge and discharge a couple of times for full capacity and longevity of the battery.
May 27, 2014 | Electronics - Others
We are a NGO in Guinea where there is no electricity. We are working with a generator to power our fridge. My question is if we can connect an energie station to the generator to charge it and then later...
well i guess it ok to use or connect energy station..but you need a higher battery to use.because we are talking fridge here..i think number of batteries you need for long life of the energy station..i suggest why trying solar energy to save much fuel..i hope it helps..
Jul 21, 2011 | Monster Cable Monster Mobile PowerStation...
HOW DO I CHARGE THIS
Just Connect in line the same as you would with a fuse. Battery to the cap and then cap to the Amp. There is no step to just"charge it" per say. All it really does is provide that little extra energy your amp requires when hitting really low frequencies.
Apr 03, 2010 | Power Acoustik 2.0 Farad Capacitor Pcnc...
2007 polaris trailblazer not charging how to test
I would start by making sure your battery is fully charged then with the battery connected, use a multi meter to measure the amps going to the battery while you have someone hold the throttle steady at different rpms. then you can check the capacitor charge coil resistance I think its the black/red to brown/white 120 ohms black/red to ground infinity and white to ground zero ohms. Hope this helps.
Mar 25, 2010 | Polaris ATV
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Weak reception, broken surface mount component
You can not find any schematics for the Magellans.  The schematics are classified.  Even when repairing GPS's for Magellan we didn't receive full schematics.  If your talking about the RF cable connector on the I/O Board (the board attached to the rear housing), then it's an easy solder fix.  For the capacitor/resistor:  I'm not sure where you found the capacitor origin, but if it's black with four legs coming off and parallel with the IC then tell me and I'll msg you back the rest.
Oct 09, 2007 | Magellan RoadMate 700 GPS Receiver
How to open case to perform tests
Remove the metal circle oposite to dial (it's glued). Under the circle you will find a metal clip connecting halfs of the flash - pull it out. Flash is ready to open.
Mar 04, 2007 | Vivitar 283 Flash
Computers & Internet Logo
115 people viewed this question
David Payne
David Payne
