Question about Samsung DLP HL-P5663W 56" TV
TRYING TO REPLACE DLP LAMP;BALLAST POWER ;POWER SUPPLY
Is there a schematic available for viewing.
osborne382
  • 306 Answers
SOURCE: SMASUNG DLP 50 HDTV
defininatly the fan that cools the lamps is either not working or going out and needs replaced
Posted on Nov 13, 2007
jerryg50
  • 1667 Answers
SOURCE: TV WILL NOT POWER UP
The ballast uses open ended high voltage. Both the start current, and the running voltage must be verified.
Normaly the ballast is replaced unless you have the test jigg which is essentialy the specified lamp simulator.
If there is a sensor fault that indicates there may be a potential cooling problem, or an unsafe fault condition (bad socket), or if the lamp is sensed as being defective, the ballast will be shut down.
Jerry G.
Posted on May 06, 2008
SOURCE: Samsung DLP HLM-617W/XAA
with lamp out (door closed) the ballast should "strike" or give an arc sound, trying to fire the lamp. If it does not do that maybe the color wheel is not spinning up - has to do that first.........then the set will try to fire the lamp
Posted on Jul 29, 2008
  • 58 Answers
SOURCE: Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Posted on Apr 25, 2009
  • 32 Answers
SOURCE: Samsung DLP
Yup definitely sounds like the ballast, if not then you have a problem in the power supply. Probably some bad capacitors. Call a local tv repair shop.
Posted on Jan 20, 2010
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
How can you tell if you have a bad lamp or ballast on the Sony DLP KDS60A3000
Remove and examine lamp to see if shattered--lamp has a 2,000 hour lifespan and may look good--if it fails the lamp light on sets front should light.
A ballast is harder to call--can check the approx 300 volts from the power supply to see if it shows at ballast.
Video instructions for lamp replacement are by model number available on You Tube for most sets.
Apr 03, 2012 | Sony KDS-60A3000 60" HDTV
I have a infocus IN35 that at 100 hours burnt out a bulb. Thinking that it was just a bulb problem I bought a new bulb and it lasted 20 minutes. a t.v.repair shop said its probably the ballast that is the...
It is not a common problem. Ballasts rarely need repairs. Have you reset the lamp hours to zero after installing new bulb? If, yes to confirm about ballast please ask the TV repair shop man whether previously he had repaired any DLP projector. There is lot of difference in technology of DLP projector & TV (except DLP Projection TV). The problem could be in the projector main board. The lamp lights after getting Lamp ON signal from the projector main board. As the lamp ignites the ballast sends the signal of Lamp Lit. If the projector board senses that any blower/exhaust fan or colour wheel is not running then it will send a signal to Switch OFF the lamp. If you are tech-savvy then do as follows to check about lamp & ballast. Remove 5 pin connector from the projector. Connect projector to mains supply. Get a 5V DC power supply. Connect +ve to pin 3 & -ve to pin 4 of the ballast connector from this supply. The lamp should light. If it does not light then there is problem in the ballast (if the lamp is new). To give a chance you can check it for your lamp which lasted 20 minutes. Generally ballasts are made by OSRAM. You can get the ballast from OSRAM dealer. You will need the part number for that. Take out the ballast, it is there on it.
Apr 14, 2011 | InFocus IN35 Projector
JVC DLP MOD#HD55G466 what is the voltage from power supply to ballast and into the lamp.I have no voltage to the lamp could it be ballast?
Ballast board gets voltage from power supply connector CN90BL and volts readings are as follows:
Pin-1 = 380V DC
Pin-2 = Ground
Pin-3 = 15V DC
and output of ballast board would be 12,000 volts AC that goes to lamp to generate spark in its electrodes to produce high bright light.
If you get volts on input of ballast board but still lamp does not fire up then ballast board is not working.
Ballast board part number is QAL0765-001 and available with tv-part.com for $125
Hope these info will help you.
Thanks.
Nov 16, 2010 | Televison & Video
I am trying to locate the position of the ballast for a Samsung DLP, model # hlt5075s tv. I am pretty sure this is the problem w/the tv going dark after several minutes and have a description of how to...
The ballast is easy to locate. Simply follow the two wires from the lamp connector. They lead strait to the ballast board.
The symptom you describe could also be a lamp if you have not yet checked that. As the lamps get older their resistance increases putting stress on the supply or ballast. You may see fluctuation in brightness or the lamp may power off after a time but will not yet be competely blown.
Jan 06, 2010 | Samsung HL-T5076S 50 in. TV
Why does my samsung tv cut off by itself after 1-2 min and flash a red lamp button?
A little explanation first- this model (as do most Samsung DLP sets) will try 3 times to get the lamp lit before the microprocessor will give up and then the 3 lites on the front will blink indicating a LAMP failure. This process takes about 1 to 2 minutes. In order of probabilty, the failures are:
1) A faulty lamp and/or ballast. REPLACE LAMP AND/OR BALLAST
However, a faulty lamp and/or ballast are not the only things that will give this blink code-
2) If the color wheel has a bad bearing and turns too slow or not at all, the microprocessor WILL NOT let the lamp light, and then give a LAMP blink code. A bad color wheel will normally have some sort of abnormal sound- a low growl or high pitched whine is common. REPLACE COLOR WHEEL
3) ALSO, if the microprocessor (on the DMD board) in its color wheel rotation detection or processing fails, once again the lamp is prevented from coming on and you get a LAMP blink code. REPLACE DMD BOARD
IF THE SET EVER COMES ON WITH A PICTURE for even a fraction of a second or though it takes many tries, the lamp and ballast are good. The problem must be either the color wheel or DMD board.
Oct 26, 2009 | Samsung HLR5064W DLP Projection TV
My Toshiba DLP Projection TV (52HM84) will not always power up. It sometiems goes through five of six retries. Is it the paower supply or maybe a related part (capicitor) ?
Pull back make sure Fans are clean ,But if you have never replace Lamp ,Lamp needs to be replace call Mats 1-800-628-1118 Rember also Ballast board is what turns Lamp on For Ballast board call Encompass 1-800-638-3328
Sep 26, 2009 | Televison & Video
Trying to find a ballister circut for a toshiba 62hm95 and is it something that i can replace myself
The Ballast is the correct wording.IT has four
screws and plugs into the lamp.very easy to change.
Sep 04, 2009 | Toshiba 62HM95 62" DLP HDTV
Samsung DLP HL-P5663W 56" TV Logo
103 people viewed this question
Henry  Thomas
Henry Thomas
