Question about Jade Ovens
We have a Jade stove. The entire range works properly. (Stove top, grill, flat top grill, left side oven-warmer) BUT the main oven does not work at all. NO heat -- lights are on as you would expect. What do you think the problem is?
    Brigadier General:
  • 3,513 Answers
Thanks for writing to Fixya.com.
You most likely have a wire loose. This happens from the popping of the circuit breakers to the stove. It is only the stove that is effected . You need to shut off the breakers to the stove only, then push the breakers past the offsetting. This resets them. Then try turning them on again. As long as the switches on the stove are OFF, there should be no problem in using the other burners, but do NOT use the one that sparked. If the breakers shut off or it sparks again. Shut off the breakers and call a licensed appliance repair person.
http://www.essortment.com/home/gasstoveburner_symo.htm
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on Apr 27, 2010
1 of 2 bulbs in upper unit stopped working. I replaced the bulb 10W, 12v & both bulbs worked. Later, both bulbs stopped working. Both bulbs have continuity. New bulbs don't fix issue. Ideas??
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=53
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Thermador Range/Stove/Oven Parts - RepairClinic.com
www.repairclinic.com/Shop...Parts/.../Thermador-Range-Stove-Oven-Par...
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
[PDF]for Thermador Professional Series Built-in Wall Ovens
www.msaworld.com/.../Service-Manual-Therm-Pro-BIWO_RevA3.pdf
Dec 19, 2015 | Thermador C272 Electric Double Oven
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
I have a 2 yo fridgedare stove that the oven went out..the stove top is working but now oven isn't? The other day while i was cooking a loud noise like a "boom" happened and now oven not working?...
The noise you heard was probably the oven element short circuiting to earth. If the cooktop and grill are working then the fuses, internal/main must not have blown. If this is the case the oven indicator light should come on when you turn the oven on. If it does the oven element is definitely faulty and needs replacing.
Mar 05, 2011 | Frigidaire Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Left front burner will not shut off
Get the Model number of the data plate on the oven so I can help
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Our frigidaire flat-top electric stove stopped working
Sound like you make have a loose neutral on the cord where it attaches to the range or in the electrical receptacle where it plugs in, you can check the cord by pulling the range out, remove the small access cover to the cord connection area, after you have unplugged it and just tightened all the nuts to all connections on the cord. I advise an electrician to check the receptacle. I hope this has helped you. Have a great new year.
Dec 28, 2017 | Frigidaire FEB27S5A Electric Single Oven
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Jun 16, 2009 | Ovens
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
Top Jade Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you a Jade Oven Expert? Answer questions, earn points and help others
