Question about Motorola Mobility W510 Mobile Phone
I don´t know why my battery is discharging so fast! I´ve had to charge it every day, with almost none calling or texting.
    Problem Solver:
  • 15 Answers
Buy a new battery. This will make your phone act normal again.
Posted on Apr 27, 2010
Cannot send or receive texts
if your plan includes text(data) then you need to contact your service provider .
Dec 17, 2015 | Samsung Galaxy Exhilarate AT&T
OBD2 CODE READER P0562
fully charge battery and make sure everything switched off i.e rear window demist etc and take it for a run to get it up to tempature then park up rev engine at fast idle approx 2750 rpm for 180 seconds then take foot off throttle and allow to idle for 30 seconds this will clear your catalyst and get it up to the 600 degrees needed for it to operate properly this should remove the engine warning light
Apr 21, 2013 | Mazda RX8 Cars & Trucks
Very low battery life
I have the same camera. It sounds to me that there is a fault with the camera itself and not the battery. You might be better sending Canon an email and asking them. My battery lasts forever so I would think if you already purchased another battery you've eliminated that problem. It might be the contacts inside the camera that are not accepting the full charge. Does the camera battery on screen show that it's full after you've charged it? Maybe trying charging it overnight and then trying it out the next day.
Dec 27, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
I have two Mecablitz 60 CT batteries. They are about 10 years old and have not been charged since March, 2004. Should I dispose of them or can they be repaired for a reasonable cost?
The couple of dryfit batteries I've looked at have been shot. I don't know how old they were. Take a decent modern battery charger (the ones at WallMart are good enough) that will handle 6 volt and AGM batteries. Clean the contacts and jury rig a way to connect the charger to the battery terminals. If the charger doesn't register anything, it's likely the batteries have died. They will actually completely dry out inside, becoming inert. I've used $20 AGM batteries from Batteries Plus and they seem to work fine (though you either need to make a battery adaptor, or cut out the side of the battery pack to get them to fit.
Sep 11, 2011 | Metz Mecablitz 60CT4 TTL Flash
1998 Cadillac Seville battery drains over-nite. I've pulled all fuses in car and still on the negative side 1.3 amps are pulled. I don't know where the grounds are located. B UT STILL WHERE CAN THE...
Hi, I would replace the battery. It has what you call internal discharge. That means it will no longer hold a charge. Also have the alternator checked that is charging properly. That should do it. Good luck.
Aug 23, 2011 | Cadillac Seville Cars & Trucks
I´ve opened the camera to clean it up
1. You shouldn't have opened it. 2. You probably shorted out the capacitor...lucky you didn't get burned. 3. You need repairs...bring lots of money.
Mar 04, 2010 | Sony Cyber-shot DSC-W35 Digital Camera
I´ve a pda hp h5455 that don´t start , i´ve tried to do a hard reset and charge it via USB and nothing hapens
To do the hard reset, while on battery (NOT A/C) power, hold down the two outside front-panel buttons (Calendar and iTask), While holding them, press the reset button with the stylus. Keep these buttons all pressed until the image on the screen begins to fade (about 4 seconds), then you can release the reset and application buttons. To restart your iPAQ, you must then plug the unit into A/C power, or do a Soft Reset by again, pressing the reset button with the stylus.
Nov 21, 2009 | HP iPAQ H5455 Pocket PC
Problem with Panasonic NV-DS38 Mini DV Digital
I´ve had same trouble, nothing help me to get tape on, then I tried to recharge the battery (new spare battery, only had 2 earlier charge) and voilá, it work´s again. So there was somekind of trouble with the new battery I got, that is not original part I don´t know if that matters,
Nov 06, 2009 | Panasonic NV-DS38 Mini DV Digital...
Discharges very fast
it may be ur battery problem may b u replace ur battery or minimal use of display settings.,n regarding the reconizing of memory card..it may work wit some reboot method..stil check out ur battery first.....try it..if it works do rate me
Apr 06, 2008 | Motorola Mobility A1200
Battery fast discharge
Battery is probably at the end of its life or then there is a problem with the motherboard causeing it to consume greater amounts of power, only solution to that would be to replace the motherboard.
try with a difrent battery?
Dec 17, 2007 | AnexTek SP-230 Pocket PC
Motorola Mobility W510  Mobile Phone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
