Question about Troy-Bilt Pony Garden Tiller
Gilson tiller belt replacement
I have a Gilson, mod 51114 garden tiller. I need a replacement drive belt and instructions on how to properly thread it arount the pulleys. Operating manual would help. Appreciate anyone's help.
5 Suggested Answers
SOURCE: both belts shredded. Atlas garden tiller model 12 -5100
I bought a repair manual from Clymer and found the belt sizes for my Atlas 12.5022 tiller. The manual lists a 1/2 inch by by 36 inch forward belt and 1/2 inch by 32 inch reverse belt for the model 12-5100. Good luck. Don't bother to buy the Clyme manual. It isn't very complete.
Bob Mortimer
mortimer5918@bellsouth.net
Posted on Apr 27, 2009
  • 69 Answers
SOURCE: looking for belt diagram for gilson brothers
Gilson stuff was eventually bought out by Toro. You may want to try the Toro website for some asnswers.
Posted on May 06, 2009
bohardin
  • 13 Answers
SOURCE: I have a Gilson Bros. Rear Tine Tiller. I need
check and if the end off axle has a swelled place use a file or sand paper to smooth it out.try some penetrating oil that will help
Posted on Jul 12, 2009
  • 112 Answers
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Posted on Jul 18, 2009
Gilson gil35210b manual
Montgomery Ward GIL 39012B Owner Manual
Gilson provided Montgomery Ward with the tiller.
Here is a link to the owner's manual.
Good luck.
Semper Fi,
Z
Feb 20, 2018 | Gilson Garden
I need a parts manual for a rototiller Gilson 7Hp model 462 42045 with a serial number 920437
Give this a shot. not sure what your after (I know parts manual) but availability is vauge----they do have sections with info of certain items pertaining to your tiller---you may be led to what you need
https://www.google.com/search?q=parts+manual+Gilson+7Hp+model+462+42045+tiller&rlz=1C1NHXL_enUS713US714&oq=parts+manual+Gilson+7Hp+model+462+42045+tiller&aqs=chrome..69i57.15739j0j9&sourceid=chrome&ie=UTF-8
Jun 11, 2017 | Gilson Garden
Gilson roto tiller model 51082
Something in the wheels drive is jammed preventing them from turning. That is why the turning belt starts to smoke when it is turning but cannot unstick the wheels. Need to unstick them for unit to work.
Apr 01, 2016 | WI Gilson Bycast Club Chair
I have a gilson tiller mod number 51182-4857 ser5266b1828 i need to get the belts for it
I went to my local small engine guy with the old belt and ended up getting one a bit smaller but works great. Fake it till you make it. Good Luck!
Sep 19, 2011 | Garden
Need to see belt route for gilson bros. tiller
You did not state if it was a front or rear tine tiller. This is for the front tine tiller:
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
The rear belt has a 1/2 twist in it for reverse. The front belt goes on nomally.
If this does not help you I would like a model number if you can locate it so I can get your the proper routing diagram.
Kelly
Apr 14, 2011 | Troy-Bilt Garden
Gilson Chain Drive Rotary Tiller Model No.51147A Serial No.2105F1 need an Idler Pulley Assembly Part No.33632 can I get one?
here you go, Good Luck Tim:
http://cgi.ebay.com/13-435-REPLACES-Idler-Pulley-Assembly-Gilson-33632-/280543748522?pt=LH_DefaultDomain_0&hash=item4151b5e1aa
Apr 01, 2011 | Garden
Hi ya got a old ish tiller in for repair, it is a ISEKI AC40 problem is hard to start & when it starts it will only run for about 10 seconds, so far checked plug which has a good spark, compression ok,...
From your description we will assume it is flooding. If you suspect float problem, check float level, holding the carb upside down the float should be parallel to carb body when needle seat is closed. On metal floats this is accomplished by bending the tab that rides on the needle, units with plastic floats you may have to replace it. Also remove float and shake it, should not be any gas in the float, this will make it flood. Also set carb adjustment screw at 1.5 turns out, may need a little tweek from there.
Oct 05, 2010 | Garden
Broken belt
The web site below sells Gilson belts - you need the part number. If you do not have the part number, maybe if you contact them, they can match the belt to your tiller number.
http://www.psep.biz/store/gilson_tiller_belts.htm
Also, another web store, Jacks small Engines (jackssmallengines.com) states that they carry parts for Gilson, but I did not find Gilson in their directory. You may have to contact them.
One of the web sites mentioned that at some point Gilson was bought by Lawn Boy. If you go to a local Lawn Boy dealer, they may be able to match up a belt.
I have a 1978 WheelHorse tractor. The drive belt for the mowing deck broke. I went to Home Depot, spend a good 1/2 hour measuring belts, and found one that works perfectly. If you go to your local outdoor equipment shop, especially one that sells, repairs tillers, they may be able to match up a belt for you. A belt is a belt is a belt. If you go to a "good old fashioned shop" that will spend the time, they can measure the old belt and hopefully come up with a match.
Good Luck!
Jul 29, 2009 | Garden
Just need to see the order in which the parts go back on the drive assembly for a Ward/Gilson 1575 front tine tiller
which drive assembly do you need info on,the belt drive or the gear box/case ***'y,I have a manual and can send a pic if needed,plus I have microfiche also on most of the Gilson jed1950@earthlink.net
Jul 16, 2009 | Garden
Looking for belt diagram for gilson brothers tiller MOD#51134G 469251
Mar 25, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy-Bilt Pony Garden Tiller Logo
347 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
