Question about Hayden Industries SuperVac 6000 Central System Vacuum
Hayden Premier Motor Pulses
When power is applied, whether remotely or directly to the main unit, the motor pulses on and off. The unit is about four years old. Any suggestions?
  • 25 Answers
There are several possibilities here, its possible the low voltage relay is bad, possible that the carbons on your motor are worn, or may even be a thermal sensor in your unit shutting it down, ive even seen improper assembly of motor which cause wires to be pinched and have shorts in them from the manufacture, course always check your power cord to the wall and test your outlet with some other appliance.as you can see several possiblities, most of which unless your knowledgeable in electricity i wound not atttempt on my own. highley reccomend taking to a vacuum cleaner shop to have checked out at least, they may even be able to sell you the part to fix it yourself
Posted on Mar 27, 2008
SOURCE:
Dc59 pulsing
i am the same problem too.
Jun 16, 2014 | Dyson DC35 Handheld Vacuum
How to get into Hayden super pack delux vac unit
Are you speaking about the Power Nozzle? If so, you need to remove the head light cap. It has clips on each side. Using a small flat head screwdriver gently pry the light cover off from the sides.
Now you will see two screws. Remove those screws. Now you need to pull out on the sides of the cover while hinging it from back to front.
That is it. There is the motor, belt and electronics.
To reassemble, just revers the steps.
May 23, 2014 | Hayden Industries Vacuums
Machine pulses and low pessure
Replace your belt. Replace your bag with a new one. Check for clogs in any hoses or areas from the brushroll up to the disposal bag area and remove them. If these steps do not help, your motor will need replacement or service. On any motor there are "brushes" on either side of the armature. When the brushes wear thin, the armature will hesitate to spin and in effect, you will have a pulsating motor, with ineffective suction.
Nov 15, 2010 | Vacuums
Similar problem with unit not turning off--
Here is a trouble shooting guide that discusses telling whether it is the relay or motor.
http://www.centralvacuumstores.com/cvs/trouble_help.php#runs_continuously
Jul 19, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden 6000+ wont run
Define hose works or doesn't, no suction, hose will not activate vac , etc.
Test the vac by shorting across the low voltage terminals where they enter the machine. If the vac works here your problem is in the internal wiring, at the valve or the hose to wall connection. If the vac will not run, you will need to check the motor for continuity across the motor leads.
Apr 18, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden Super Vac Premier will not stop unless I unplug
one of two problems cause this. first is a short in the wires that turn it on, the small wires going to the side of the body unplug one of them to see if thats the problem
second is a stuck relay inside the top cofer of the main body
Jan 26, 2009 | Hayden Industries SuperVac 6000 Central...
Hayden Vac2400
Check the carbon brushes, they maybe worn out and need replacing.
Jan 06, 2008 | Hayden Industries SuperVac 2400 Central...
Hayden Industries SuperVac 6000 Central System Vacuum Logo
557 people viewed this question
Top Hayden Industries Vacuums Experts
Marvin
Marvin
JoeVacs
Are you a Hayden Industries Vacuum Expert? Answer questions, earn points and help others
