Question about Watches
I can't get the pin out of my Stark watch PH1101 plastic strap buckle, thus making it impossible to shorten the wrist strap, any suggestions without having to go to a watch shop?
You need to go to a fossil shop nearby...i did and they did the adjustment for free...
Posted on Jan 07, 2011
Shortening watch strap
It depends on which strap is fitted but these normally have removable links that can be removes with a watchmakers screwdriver near the divers buckle.
Jan 05, 2014 | Breitling Superocean GMT Mens Watch...
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
How do you shorten the metal band to make it fit your wrist?
If you do not know how to shorten the strap, the simplest answer to your problem is to take it to your nearest watch shop. Most of them will be able to do it for you for a small charge.
Dec 11, 2010 | Casio GW810D 1 Digital Shock Watch
I am trying to figure out how to shorten the wrist band on my Casio Edifice EFA-119.
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
Aug 03, 2010 | Casio Edifice EFA109-7AV Wrist Watch
Need to shorten the band on a Timex Ironman Triathlon
These pins will definetely come out- poke a bit harder. You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Jan 04, 2009 | Timex Ironman Triathlon 50 Lap Digital...
Shorten strap of Casio Edifice EF-518 watch
good morning ! thats verry easy to make shorter !just look the possition of arow and push the pin to out use the pointed tool and anvil to releas the pin ! thank you !god bless !....
Sep 01, 2008 | Casio Edifice EFA109-7AV Wrist Watch
Invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
May 15, 2008 | Fossil PH1057 Wrist Watch
Leather wrist strap
I would scrap the strap - the odours are caused by the tanning chemicals getting wet. Retain the fastening and purchase half a meter of nylon ribbon loop it through the case pegs on one side glue them together and pierce for buckle holes. On the buckle side loop it through both case peg and buckle and fold and glue. You have a choice of colour and it cost only fraction of a new leather one- also you will have enough left to make two straps
Sep 12, 2007 | Field and Stream F25SLUMI Wrist Watch
Watches Logo
190 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
