Question about Maytag Neptune MAH5500B Front Load Washer
We had a Tech come out and said we need a new Outer drum. Machine is still working but, loud. WIth labor it is 792.00 to fix through Maytag at Sears
  • 1,998 Answers
Sears is actually one of the highest appliance repair sevices if you want to cut some money off the price shop around smaller companies with knowledgeable technicians will save you over 100.00
Posted on Apr 29, 2010
Kenmore Elite H3 washer's loud in spin cycle & smells burnt.Debris & plastic in well inside washer.Pushed aside rubber ring & saw lg. gap btwn. metal drum & surrounding plastic.Parts needing replace?
It sounds like the drum has broken from the rear mount. This will chew up the outer shell. This is a very labor extensive job. The parts are expensive also. You will probably need a new outer shell and inner drum.
May 29, 2015 | Kenmore Washing Machines
Loud noises during spin cycle. Drum is eating up. All springs and shocks appear to be ok
The water seal has worn out and water has gotten into the bearings. You need to call a service tech to have it repaired. It is not a cheap repair. Whirlpool has a repair that replaces the back half of outer tub and a new inner tub or basket one in the same. Another salution is replace the seal and bearings, still a lot of labor. go to utube and a guy does to an LG, but the the repair is about the same for a Duet
Aug 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite quiet pak 2
No it is very expensive to repair. You have to buy the whole rear portion of the outer drum if it is the bearings. Or a tub spider which holds the inner tub to the spindle that spins it. it is a very labor intensive repair. you would also need the outer tub seal/gasket for reassembly. If you are a skilled mechanic you may be able to repair it cheaper than a new one, but be prepared to spent the better part of you weekend working on it.
Nov 16, 2013 | Washing Machines
Managemylife
If Sears in Santa Rosa could not help you with the purchase of a replacement washer, maybe you should consider buying something other than a Sears machine.
Nov 06, 2013 | Kenmore Washing Machines
Maytag neptune washer noisy when in spin cycle. also there's a small hole located in the back of the machine on the drum with metal shavings coming out of it. The noise is a loud grinding noise. could...
You have a bad rear bearing in the outer tub. The entire outer tub would need to be replaced to resolve this issue.
Check your owner's manual to see what kind of warranty you have on this part. I'm keeping my fingers crossed for you as this is an expensive repair!
Good luck!!
Jun 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
WHEN SPINING MAKING A LOAD NOISE
your drum bearings have gotten water in them from the lip-seal on the drum drive shaft,you need to remove the rear access panel,remove the belt remove the pulley,then remove inner tub and remove the spider that holds the inner drum on,then remove old seal and replace the inner and outer bearings,dont do just the inner bearing as the outer one isn't that expensive and may go out later,and its very labor intensive,anywhere from 2 to 7 hours depending on how stuck the old bearings are in the machine
Mar 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud noise(not jet whirring sound) during rinse & spin cycles.
the rear bearing is bad the bearing is press in to the outer tub the outer tube is like a **** shell you need the rear half and new seals it is a big job if you are going to do it you will need a manul
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Spin Cycle
Yes its true the main support bearing is part of the outer tub and is factory set .Dry bearing will roar until it develops a leak and eventually starts a main pulley shake that will cut through the back of the outer tubs shell.The outer tub costs about $175.00(varies)the labor (please sit down)yes, is high enough for you to go out and find your self a 15 year old Maytag top load, re-build it,scrap the front load,and never see a repairman for the next 15 Years.No joke!                             I/m happy to help you with anything you need a answer to.............Sorry about your Maytag    :(
May 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Washer/Dryer Combo purchased in late 2000
Call a local repair tech. I know one in Milwaukee :)
Seriously, your machine needs some possibly expensive repairs beyond a novice's skills. The dryer has a felt bearing around the front of the drum that is probably worn out. Check on the rear bearing and the belt at the same time. The washer may need a new transmission, belt, tub seal, and spin bearing. That's an involved repair. Expect to pay extra for labor, but the total bill should be less than the $800 - $1400 for a new machine.
Mar 12, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
