Panasonic kx-p1180 driver for win xp
Pls help i have tried to load my printer thru windows but it does not print . i have also tried the epson fx 80 but no luck
pls help
  • 286 Answers
If you still have this printer, go to control panel and click on add new printer (after plugging the printer into your parallel port and turning it on).
During installation it will ask you which port to use, select the PARALLEL port, NOT USB or ethernet/LAN. It will then ask you to select a driver, choose Panasonic and go down the list and select the correct model number. It will install a driver and ask you if you want to make it the default printer, select YES and allow it to print a test page.
Posted on Dec 30, 2010
  • 2,072 Answers
A couple of questions first. What type of connection are you using? Are you using an ethernet cable or USB?
If you are using ethernet, I suspect either an address problem, IP address, or a firewall problem.
I will be glad to work with you on this, but I really need to know how your trying to connect.
Posted on Mar 24, 2008
Where can I get a driver for a dot matrix printer KX-P1150 I am using windows 7
There are no Panasonic driver that will work , however Use EPSON
FX Series 1(80) INBOX Driver*1 instead. It will work a treat!
Oct 20, 2014 | Panasonic Kx-p1150 Kx-p1150 Dot Matrix Pr
I want to download Panasonic Printer Model NO. KX-P1131 for windows 7
For your "Panasonic KX-P1131 Matrix Printer" just use the "EPSON LQ Series 1(80) INBOX Driver" for Win 7(X86 or X64) from your Win 7 CD. Select the LQ 850 Epson driver from add printer and & install the drivers and it will print just fine.
Reference link @
Hope it helps.
Jun 13, 2011 | Panasonic KX-P1131 Matrix Printer
You might have to use EPSON FX Series 1(80) INBOX Driver*1
what *1 means - INBOX Driver is Printer Driver that is included in Windows 7. so all you need is to go to Control Panel - Printers and Scanners and choose EPSON FX Series 1(80) INBOX Driver as your driver fot your Panasonic printer. This advice was recommended by Panasonic, I have tried to locate the driver for Win7 but no luck I hope this works for you. Good Luck
Jun 10, 2011 | Panasonic KX-P1150 Matrix Printer
Como instalar impresora panasonic kx-1150 con windows 7
Usa los drivers para EPSON FX Series 1(80) que se encuentran en Win 7.
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Mar 08, 2011 | Panasonic KX-P1150 Matrix Printer
How do you get Panasonic KX-P2023 to print 8.5" x 7" tractor feed using Windows 7?
for 32 bit
LQ Series 1(80)
INBOX Driver*
1 INBOX Driver is Printer Driver that is included in Windows 7.
Mar 18, 2010 | Panasonic KX-P2023 Matrix Printer
Wants to get drivers to run in win 7
This driver is in the Windows 7 default driver data base
Just let windows 7 install the driver for itself.
Feb 01, 2010 | Office Equipment & Supplies
Driver needed for panasonic kxp1124i printer
I found this at the bottom of the page at this Panasonic Website:
  • Regarding the following printers, Printer Drivers are included in Windows XP CD-ROM as standard
Category Model Monochrome Laser Printer KX-P4410, KX-P4420, KX-P4430, KX-P4440, KX-P4450, KX-P4410i, KX-P4451, KX-P4455, KX-P5400, KX-P5410, KX-P6500(PCL) Dot Matrix Printer KX-P1081, KX-P1121, KX-P1123, KX-P1124, KX-P1124i, KX-P1150, KX-P1170, KX-P1180, KX-P1624, KX-P1695, KX-P2023, KX-P2123, KX-P2124, KX-P2130, KX-P2180, KX-P2624, KX-P3123, KX-P3624
Mar 16, 2009 | Panasonic Office Equipment & Supplies
398 people viewed this question
