Question about Husqvarna 19.5hp 46" Yard Tractor
I have a husqvarna logth2448t. won?t start,
I have a husqvarna logth2448t. won’t start, battery is good. How do I locate and test starter or soleniod
2 Suggested Answers
  • 376 Answers
SOURCE: Will not Start
There won't be any voltage going to the starter until the key is turned to 'start' with the brake locked down. And to check that, you need to disconnect the wire to the starter. I would first check the current going to the solenoid when the switch is turned to start by disconnecting the insulated wire going to the bottom of the solenoid and hooking a test light or voltmeter to it and turn key to start. Again the clutch/brake pedal has to be held/locked down. If there is power going to the solenoid but not to the starter, it's a bad solenoid. Hope I've explained this so you can understand. Dwain
Posted on Jun 15, 2009
Willnot turn over.battery good and at 100%.fuel pump kicks on and relays by fuse panel click when trying to stat
The click you hear is the starter soleniod. My guess is that either the starter is bad, or the soleniod is bad. Try jump starting the car for the heck of it. If it ends up being one of the other 2 things, make sure the person tests BOTH the starter, and soleniod. A starter is a LOT more money, and lots of times they'll make you buy a starter, even though its just the soleniod!
May 04, 2015 | 1991 Nissan Stanza
2005 electraglide won't start
Hi Anonymous, first when checking anything in the starter circuit you must make sure the battery connections are clean and tight especially the negative cable at both ends and has a 12.5 volt or better charge. It must not fall below 9 volts during the cranking procedure with a volt meter hooked up. If it does fall below 9 volts do a proper load test on the battery and replace if necessary. Second replace the starter relay cheap $6 and make sure it's well grounded and getting 11.5 volts or better to activate. Third remove the back cover of the starter solenoid and de-arc/refurbish the contact plate and shoes making sure they are tight. If it still chatters replace the solenoid. Good luck and have nice day.
Apr 08, 2012 | Harley Davidson FLHTCUI Electra Glide...
I have a John Deere L110 that won't start. Mowed grass then parked it and it wouldnt start. These are all of the things we have done: New spark plug, solinoid, all 3 safety switches, battery terminals...
problem could be: brake pedal is not depressed; PTO is engaged; battery terminals are corroded; battery not charged; blown fuse; or fusible link in starting circuit is blown.These are the Most Common Causes for your Problem. Recheck your voltage of the battery and then check it under a load....Take a Jumper Cable Set and Attach the Positive Lead to the Positive Post of the Battery. Take the Other End and FIRMLY Touch the Large Post of the Soleniod on the Starter Side. If the Starter Turns the Engine, then Check the Voltage from the Ignition Switch to the Soleniod. If the Voltage is Going From the Switch to the Soleniod When the Ignition Switch is in the Start Position, then Replace the Soleniod. If No Current from the Ignition Switch to the Small Post on the Soleniod, then The Ignition Switch is Bad ....Hope this helps
May 07, 2011 | Husqvarna Viking 1
New starter new soleniod and battery just get buzzing from soleniod no start
Try to test the starter in question on a bench to verify if it's good or not. Also, test the battery to verify charge and Cold Cranking Amps on it.
Good luck on this repair.
Jan 27, 2011 | 1991 Mercury Sable
Just went to start blazer, starter won't turn over, all other electrical works. Battery is good any idea's?
Check the electrical connections to the starter.
If sounds like the starter may be bad.
If you remove the starter and take it to autozone, they will test it for free
Jan 16, 2011 | 1991 Chevrolet S-10 Blazer
MOTOR OPERTAES WITHOUT KEY
your starter,solenoid or ignition is no good. but my first choice,i think your solenoid is shorted because when you hook up the battery,it cranks but does not start.that means your ignition switch is still working.
Jul 22, 2009 | 1990 Ford F150
Will not Start
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
TRUCK JUST STOPS RUNNING
Experience is the best teacher.
Mar 14, 2009 | 1999 Ford Expedition
Engine won.t turn
hi can you turn engine over by hand [engine s not sezied ] and how did you test the battery and how did you test starter because if the engines not seized and you put a jump lead from your positive terminal off a good battery to a starters main terminal and it wont, turn over the starters faulty or there is no engine earth so connect the other jump lead from the negative battery teminal to the engine block and try again it will turn over if the starters good if the starter turns over with the jump leads check the small terminal on the starters wire is live when someone turns the ignition key if it is and the starter does not turn over then the soleniod on the starter is faulty if no live at small terminal then the ignition switch or starter relay are faulty best of luck yates2104546
Oct 14, 2008 | 1994 GMC Jimmy
Husqvarna 19.5hp 46" Yard Tractor Logo
125 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
