Question about Airlink Router
Lack of data transfer when cell phone is connected to router
When I use the wifi on my cellular phone to connect to the router (Airlink Mimo) it will show that it is connected and will initially transfer data. After a while, usually as little as a couple of minutes, my phone says that it is still connected, but I cannot receive or upload data. I've tried moving all the wireless house phones at least ten feet away from the router, but this issue did not go away.
Thanks in advance!
    President:
  • 1,768 Answers
1.Use the USB dongle to the PC and see if you can transfer your data complete
Posted on Apr 29, 2010
If my wifi connection is good how come my fire stick won't work
reset your router. a lot of times your wifi signal strength is good but no data is being transferred. on a computer you would notice a orange triangle hovering over the wifi strength indicator denoting no data is being transferred, but a fire stick doesn't have that feature built into the firmware. so reset the router or reset the first stick and the connection should be re-established.
Nov 17, 2016 | Computers & Internet
Tip
How to connect an iPhone to the Internet
Connecting your iPhone to the internet is an easy process. You just simply use any application on your iPhone which uses internet service.
Your iPhone can either use WiFi or Cellular for internet access.
- A WiFi network is simply a wireless network. You can find them at coffee shops, libraries or even at your house if you a router setup for wireless access.
- Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
When you use an application on your iPhone that requires internet service it will either connect to the last WiFi network used, or if that network is not available it will list all available networks in range. You can simply tap on the network you wish to join and it will connect. If the network requires a password it will show a lock icon. If no Wifi networks are available your iPhone will connect over the cellular data network and fees may apply.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
I hope this article was informative. You can check out more of my tech articles by clicking here then going to the Tips section.
Regards,
G33k
keywords
how to connect iPhone to the internet, connect to internet, iPhone internet, connect iPhone internet, how to use internet on iPhone, iPhone internet application, iPhone wifi, iPhone wireless internet connection, iPhone no internet, internet not working iPhone, iPhone 3g,
on Jul 09, 2011 | Apple iPhone Smartphone
I am just wondering if i watch shows using yidio does that use my data
If you are connected to your cellular network, watching them, then yes your data would be used. However, if you connected to wifi through your home internet, then your cellular data would not be used.
Sep 11, 2013 | i-mate Cell Phones
Blackberry 9300 wifi with dlink problem
Hi @ Anonymous , please forget the WIFI Network on your Blackberry and do another scan, it will ask you to enter your WIFI password again. See if it works.
Oct 30, 2017 | RIM BlackBerry Curve 3G 9300 Cell Phone
Cnnot get mms to work on htc touch pro
Make sure your WIFI is turned off when trying to download a MMS message. Most carriers do not allow MMS data to be transfered over WIFI. Your phone will us it's cellular data connection.
Feb 17, 2011 | HTC Touch Pro Smartphone
LG GW620 wont able to send MMS, download or anything related to MMS
Feb 08, 2011 | LG GW620 Cell Phone
I cant receive mms on my samsung star
Feb 07, 2011 | Samsung Star GT-S5233 Cell Phone
Airlink ar430w not giving a network address to netgear wpn111
Try assigning the IP address manually. To do so go to Network Connections, right click on the wireless connection and click on Properties, select Internet Protocol TCP/IP and click on Properties again. Select use the following IP address and type the address of the same range as of your Router's IP. In case you do not know the range try 192.168.1.5 or 172.16.1.5 with the subnet mask as 255.255.255.0 for both, and when you use the IP as 192.168.1.5 use the default gateway as 192.168.1.1 and for 172.16.1.5 use the default gateway as 172.16.1.1 Also select the lower option as "Use following DNS Server address" and for 192.168.1.5 use 192.168.1.1 and for 172.168.1.5 use 172.16.1.1 .Click on Ok. Click on Ok again and now check for the connectivity.
Jul 08, 2009 | Airlink AR430W Wireless Router
Nokia 6233 mobile switch on but then hangup
Dear
When u connect to computer by data cable it shows three option, select data transfer option from it to transfer file like videos,music etc.
while in this process phone will not displays menu option it shows data transfering
if u want to display menu option u have to deattach usb data connection
Thanks
Feb 20, 2009 | Nokia 6233 Cellular Phone
WIFI Connection Problem - connects only to EDGE
If you want to use wifi only when your at home you can go in and manually disable the cellular data so the internet will only be wifi based. Probably saving you MB's and data cost.
Go to Settings, General, Network, then simply turn off the Cellular Data. Then it won't connect anymore to the cell data and rely only on wifi when your connected to it.
And simple follow the same steps and revers the process when your out on the go.
Thanks
Oct 15, 2007 | Apple iPhone Smartphone
Airlink  Router Logo
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
