Question about Janome MyLock 634D Mechanical Sewing Machine
Left needle thread breaking
I keep having this problem reoccuring. I have cleaned it, oiled it, checked tension, but the thread is keep breaking (left needle). Is there anything i can do?
  • Anonymous Mar 30, 2014
    Needle thread tension not balanced
  • 3 Answers
My first inclination would be to change the needle. I could have been defective from the beginning. If it will serge without left needle, then you know that everything else is threaded correctly. Good luck.
Posted on Mar 29, 2008
SOURCE:
My white serger 734d keeps breaking the right needle thread. I have oiled, cleaned and changed needles.
try adjustin the tension for that needle, also check to make sure the
thread is not caught anywhere,, even if you have to rethread that
needle,,make sure there are no burrs on any thread guides also.
if that doesn't help then the machine needs to be checked.
Apr 16, 2013 | Sewing Machines
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
My serger keeps breaking the left needle. It works fine as a 3 thread but not with the 4th thread.
make sure the left needle is inserted correctly into the needle
holder, if you have flat sided needles make sure that the flat side is
put correctly to the side it suppose to be.
check the tension on the left needle, it may be too tight
Jan 19, 2013 | Sewing Machines
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Cannot get the tension right and the thread keeps braking
Good day!
Good day!
Jun 05, 2011 | Singer Inspiration 4206
Upper thread keeps breaking
the tension is too tight give it a little slack on the top.good luck.
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Janome MyLock 634D Mechanical Sewing Machine Logo
112 people viewed this question
Top Janome Sewing Machines Experts
Douglas Plant
Douglas Plant
Irene Tulloch
Thomas F. Schneider
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
