Question about Homelite Mighty Lite Lawn Trimmer
Mcculloch petrol trimmer
Mcculloch petrol strimmer x-series 250cxl 25cc/will not tick over. clean the carb plug new gasit incard clean the fillter.it got run on half cork it ok but will not tick over
5 Suggested Answers
  • 42 Answers
SOURCE: I have a Homelite 25cc trimmer. It will crank but
you either have one of two things wrong. my first guess is that you have a crack or hole in one of your fuel lines causing it to not get enough fuel. the reason it will run for a few seconds is that you pump a little fuel in when you prime it. my second guess is that you have a very plugged fuel filter or something obstructing the fuel lines. take a look at the lines all the way very closely for cracks, as this is very common in seasonal tools like these. let me know if this works. if not, i will help you get it fixed. thanks.
Posted on Mar 18, 2009
moretons
  • 155 Answers
SOURCE: Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Posted on Jul 26, 2009
  • 3 Answers
SOURCE: Trimmers: Homelite Easy Reach-25cc-Model #
sounds like an air/ fuel mixture/ratio problem.there should be two screws side by side near the carb. crank trimmer and slowly adjust screws, in or out, till engine runs smoothly..
Posted on Sep 08, 2010
hunter19_46m
  • 7482 Answers
SOURCE: diagram for fuel lines on 25cc homelite ut20811b gas trimmer
Hi martinez7568
I believe the picture below is what you are looking for.
Please take time to rate me
Bud
Posted on Oct 25, 2012
Champion strimmer 25 cc cord
its a pdf
Champion Strimmer Manual - 64.140.158.30
64.140.158.30/champion/champion-strimmer-manual.pdfhomelite: operator's manual 25cc string trimmers - owneriq - read your operator?¢?€?™s ... kimmel manual kawasaki petrol strimmer tg24 manual ' champion ...
Jul 17, 2016 | Garden
My McCulloch 250cxl strimmer wont prime, new bulb, cleaned carb, new fuel lines
switch fuel lines,the one with filter is carb,the one without is the primer
Jun 26, 2015 | McCulloch Garden
How to load new cutting line onto a McCulloch Strimmer TM250
You can probably find a Youtube demonstration video.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jul 16, 2014 | McCulloch 41201-33 Line Head, Models...
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
Petrol strimer not ticking over
Joseph check the air filter isn't blocked. Also make sure the choke isn't engaged.
Mar 16, 2014 | McCulloch 224998 COLLAR Trimmer Head Titan...
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Mcculoch mt 300mcculoch petrol strimmer carb two adjustable screw bolts ones for petrol, ones petrol & air mixture hich one does which
Actually both screws are for petrol mix. The screw closest to the engine is the Lo side. Lo side jet provides petrol at idle and during the ramp up to speed. Hi side jet (closest to air filter) only effects the mix at high speed.
From McCulloch, these were set at 1 1/4 turns out.
Sep 16, 2010 | Yard Machines Garden
Mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Jul 04, 2010 | Garden
My mcculloch petrol hedgetrimmer wont start, the pull cord has a lot of resistance. I have changed the spark plug and cleaned the air filter but still no joy.Interestingly When i remove the spark plug i...
The fact that your engine turns over easily with the spark plug removed simply means that, with the plug removed, there is no compression, so the piston goes up and down very easily.
If it has been a while since you ran the machine, and if you left gas in it, your carb may have gotten gummed up from the gas losing it viability and turning to something like varnish. You might try spraying carb cleaner into the carb (with the air filter removed), let it sit for a few minutes, then try starting. In the future, you probably should get some fuel stablizer (available at almost any hardware store) and add it to the fuel that you use for your small machines. It will keep the gas viable for a much longer period of time.
Hope that you are lucky enough that the carb cleaner, a good dose, will work. If not, you may have to disassemble and clean out your carb. (if you've never done that, a series of digital camera photos so you know where to put things back is a good idea).
Oct 18, 2009 | McCulloch Garden
Homelite Mighty Lite Lawn Trimmer  Logo
146 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
