Question about Garden
My lawn mower was working fine then it stopped and wouldnt restart theres plenty of petrol and a good spark but it wont fire up
  • 54 Answers
Lots of possibles here. I would start by removing the spark plug and checking compression. Then remove the main housing cover and by hand, slowly turn the flywheel until the magnets line up with the mag arms (coil) and check to see if your piston is all the way up in the cylinder, if not most likely your shear key (aligns flywheel to crank) is broke. Just a thought
Posted on Apr 28, 2010
Suffolk Punch 35s not starting
carburetor have a setting level for its fuel , check the floating control adjust fuel level , also check spark plug current is there,just by rotating engine and keeping spark plug out of cylinder , just keeping it with engine body.
Apr 12, 2014 | Garden
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Yard Machines 13.5 HP riding mower wont start. It turns over fast, has good spark, good gas, good filter, clean carb, just wont fire. It ran fine yesterday and i parked it last night and tried to fire it...
Hi, check that the choke is operating and make sure the plug is wet after cranking. If so replace the sparkplug as it may be breaking down under compression. Also make sure it has compression ad it may have a stuck valve. regards Phil
Jun 19, 2012 | Yard Machines 155 Torque Briggs Stratton...
Craftsman 675 series wont start
can you pull the rope and it doesn't start or is it stuck like the engine is locked up?check for spark also how old is the fuel gas is only good 30days from the pump for small engines
Jun 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Lawn mower refusing to start. plenty of petrol but i suspect it is not firing. ~Ive changed the plug still no sign of life
What manufacturer makes the motor? You could have a dirty kill switch that is preventing the motor from getting spark.
Jul 02, 2011 | Computers & Internet
My Lawn mower will not start, there is no spark, when the new plug is held against the casing. All else looks fine, new oil, new petrol, clean carb, filter. It worked ok up to a month ago, then would only...
It also could be the stop switch is not opening up. On mower you have a stop bail that a cable is attach to the engine if this cable does not open the stop switch, when the bail is pulled back, the mower will not allow the mower to start. The stop cable may need to be replaced because it is stretched out. HTH
Good Day. mate.
Oct 27, 2009 | Garden
Nannie what can be wrong with my power devil petrol lawn mower the engine wont keep running then cuts out petrol and oil ok
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Jun 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
127 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
