Question about Sharp Notevision PG-C45X Multimedia Projector
Yellow blotch on screen
I have a problem with a yellow discoration on the screen.
We have changed the bulb and cleaned the outside of the lense but without any luck. The spot originally took up only about 5 % now it takes up over 33% of the screen.
Any suggestions would be appreciated.
Brian
Blue polarizer has gone bad.
Posted on May 03, 2011
Panasonic DLP TV has huge yellow blotch covering most of the screen
SET uses a optical light engine--lamp which is quite hot shines into the engine---blue is first to get the light and heat and is usually first area in the lens and baffles to get damaged(loss of blue leaves red and green which equal a yellow screen.
You have a damaged light engine.
Apr 23, 2012 | Panasonic PT-43LCX64 43" HDTV
Picture has a yellow tint. It's from an old video game that ran over 12 hours a day. Has new bulb. Except for the yellow, works fine.
Hello there:
The best way to describe this is what is called screen burn in.
this is very common on screns that have games or pictures that arre displayed for long periods of time without being shut down just like on a computer screen when a screen saver is not used .
there is nothing wrong with the bulb.
the yellow that you are seeing is actually burned into the glass part of the projector and the lense
so if you can and feel like you can dissasemble the projector dissassemble it and locate the glass and see if you can get the yellow tint that will be on the glass and the lense off by using some rubbing alcohol and a cottomn swab
But if it wont come off you will have to replace the lense and the glass ok
Hope this is very helpful for you
Best regards Michael
Jan 18, 2010 | ViewSonic PJ501 Multimedia Projector
I have yellow and purple blotches on screen
I had this same problem on my Mitsubishi rear projection WD52527 model television. The optic engine was changed twice, and the blotches were still there. It turned out that it was the mirror inside the television that was causing the purple blotches. It was filthy and once the repairman took it out and cleaned it the discolorations were gone. Hope this helps
emmilinna
Oct 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Yellow ring on screen of KDF-E50A10 Sony Wega
The optical engine has a build up of dust. This can cause yellow shapes and blotches to appear. It is no easy task on this model to dismantle and clean the engine.
Sep 28, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
I have a yellowish tint in the center of picture
Why does my picture appear yellowish on the screen? I haven't changed the bulb in at least 2 years. Does this make a difference?
Aug 11, 2009 | Epson - PowerLite S1+ Multimedia Projector
Need to replace left year brake light bulb in a 1993 Voyager
think that when i changed the whole lights for an import as this one didnt have yellow indicators i took them all out but cant remember sorry oldtimers is catching up fast
Jan 10, 2009 | 1991 Plymouth Voyager
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Yellow band on the edge of screen
Hi chucri
This is most definitely not a lamp problem.
If a yellow colour in either stripes or blotches occur it is a blue LCD polarizer that needs replacement.
May 16, 2008 | Sanyo PLC-SP20N Multimedia Projector
Sharp Notevision PG-C45X Multimedia Projector Logo
615 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
