Question about Fowler Shockproof Dial Caliper - 0 - 6"
Fowler 12" dial caliper measures 0.025 when shut, how do I zero
Indicator measures 0.025 when shut, how do I zero them?
    Guru:
  • 509 Answers
There should be a small thumb screw near the dial that you loosen to turn the dial to zero it, then re-tighten the thumb screw.
Posted on Apr 28, 2010
How do you put a preset in Mitutoyo uni-mics?
Normally you would adjust it to the part being measured then press the 'Zero' button to zero out the display. Now every time you measure the same type of part, it should read zero or the dimension plus or minus from that zero point.
Nov 20, 2012 | Mitutoyo 317-351 Digital...
How to test a tv flyback
Two basic ways--most shops use a ringer---with flyback out they connect across the primary (where sweep transistor collector goes to where that lead on the transformer exits--a good bad indication is seen.
Second way is voltage into the transformer is tested and High Voltage is measured at the CRT---usually if transformer bad you will have 4kv or so (4,000 volts) and the suspect is clear.
If HV just comes up full (over 20 Kv) and drops to zero it is not the problem and something is shutting the set down.
Apr 08, 2012 | Televison & Video
While driving the temperature gauge goes down to zero at the same time the truck bucks (sputters) and sometimes shuts off, all the other gauges do not move. When standing at a traffic light, the temp....
You have a sensor that controls this. It is a temp sensor. It could be called something else, but it is a sensor that measures your engine temps. It would shut the vehicle off if it is not working properly.
Feb 05, 2011 | 2001 Chevrolet Tahoe
Toro Zero Turn adjustment
i have the same problem I wish I knew what was doing it I also changed the shaft and still. Could the blade be upside down?
May 30, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
I have two questions. The first is what is the
The dial is for selecting which of the "multi" things you need for measuring (metering).
Set the dial to the DC area and select 20V or whatever is the lowset DC voltage setting that is higher than the battery voltage.
The meter does not put a "load" on the batteries, so the test is just an estimate of freshness of the battery.
Notes:
The meter voltage does not present any danger to the user. If you are not experienced, do not check any AC voltages.
Oct 12, 2009 | Kitchen Appliances - Others
I have a GE gas dryer and the ignitor is a WE4X750. I tested the ohms and I get no resistance. Does that indicate it is bad for sure?
Generic comment:
No resistance indicates "short" (completed circuit). NO reading is not necessarily no resistance. Are you using a digital or analog meter? Do you have a reference value from the manufacturer?
If you measured a piece of wire, your digital reading would be zero, your analog reading would be "short" and probably zero (the needle would move to the other end of the scale). If you measure air, (a known burned out light bulb for example) your digital reading would be floating (nothing) while your analog reading would be no movement of the needle on the meter.
I would expect an ignitor would indicate some resistance (that would cause heat).
You probably already know this stuff.
Can you see where the thing is located? I think Id be looking for an orange glow as I turned the device on ... that would indicate it was working.
Oct 04, 2009 | Dryers
Hey i'm doing some school work and i have a question about the clutch fork free play on a 92 Subaru Justy. What is the Proper Free play? a) .12-.16 inch b) .25-.50 inch c) .08-.16 inch d) .75-.85...
c) .08-.16 inch The measurement point is close to where the adjustment is attach a dial indicaator (with magnetic base) to a place where you can line up the dial indicator to contact the clutch release lever, then with your hand move the lever all the way in one direction and hold while you turn the zeroing ring dial to line up with zero to the needle then move the clutch lever in the opposite direction , note the reading and adjust accordingly to bring it into spec.
Jul 29, 2009 | 1992 Subaru Justy
How to adjust Mitutoyo 505-101 caliber
You don't. What you did to adjust zero is what you do to adjust zero. Do not "go inside to adjust the dial". If the dial reads zero when the jaws are shut there is no problem.
Mar 18, 2009 | Measuring Tools & Sensors
Won't power up - Leakage Test - Mitsubishi WS-73711
Well it sounds like you enjoy checking things, did you check D9A31 part# 264P045050 and R9A33 a 220 ohm 1/4 watt resistor on the PCB? Try this!
Troy
Jan 07, 2008 | Mitsubishi WS-73711 73" Rear Projection...
Fowler  Shockproof Dial Caliper - 0 - 6" Logo
206 people viewed this question
Top Fowler Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Fowler Measuring Tool and Sensor Expert? Answer questions, earn points and help others
