Question about Sharp LC-32SB24U 32 in. LCD TV
While playing it occassionally shuts off. It can be turned back on again??? This happens without doing anything to it.
  • Sharp Master
  • 19,396 Answers
Hi.
If the TV loose power completely, and goes completely off, with no led on and no sign of life whatsoever, then the problem is the PSU board. Power cord and on off switch must be tested before replacing PSU.
If there is no led on, test using a different main socket, check power cord, and check fuse if the power cord is fused. There is no fuse that the user can check on TV.
If the TV goes suddenly in standby instead, that means that the main controller board detected a fault condition (eg. a wrong voltage or a short), and turned the TV in standby to prevent further damage to internal component.
In this case is said that the TV goes in protect mode (forced standby).
If you have not turned the TV back on yet, follow the troubleshooting on article below.
My television does not start up
If your TV turns back on, and fail again at random time, it can be a faulty PSU, a faulty controller board , or less frequently and inverter failing.
Here a broad description of how a technician must test the TV:
How to test an LCD TV or monitor PSU and...
Repair is suitable only for a trained person.
If your TV is going in standby at random times, that means that the TV is faulty. In that case call the manufacturer at the number listed on the owners manual to arrange the repair.
Here parts for the model listed in title: Sharp LC-32SB24U.
Regards.
Posted on Apr 27, 2010
Toshiba satellite p300 shutdown
You also should change the thermal paste. If you want to play games, please choose normal PC. I think you are asking too much from your laptop.
Apr 15, 2013 | Toshiba Satellite Computers & Internet
Unit will not turn back on
try to unplug it for a while and plug it back in
Mar 14, 2009 | CyberPower 825AVR (cps825avr-sc) UPS...
1999 grand cherokee jeep -coolant fan will not shut off
Hi Jeepers,
The fan will occassionally continue to run for five or ten minutes after the vehicle shuts down. This is normal.
What is not normal is if it keeps running until the battery drains.
Does it just keep running?
If it eventually shuts off, how long does it take?
Did this just start happening?
The two days you mentioned, were they short trips, opposed to the third day?
If you would comment me back with some more details, it would help me help you.
Mike
Jan 12, 2009 | 1999 Jeep Grand Cherokee
Camera Keeps freezing/turning off
Sounds like the camera is writing to the CF card. If this is after taking several shots, even worse in continuous mode. That's why it won't shut off or anything, it has to finish that before it will shut down. If you have access to one try a different card. Remember to reformat it in this camera. Page 38 of your manual. If that works for you take the card into a camera shop and ask them if they will do a low format a newer camera like a XSi, then reformat it in your camera again before you use it.
Oct 26, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Proscan PS52682 - Turns on then quickly goes off
sounds like a control pannel problem further trouble shooting
Aug 14, 2008 | Proscan PS52690 52" Rear Projection...
Mp3 rca pearl
i have the exact same problem.. but i took mine apart and broke it more... lol. it turned on, but only pearl came up and wouldnt load. the only thing that couldve made it happen was the battery died and it shut down, so i turned it back on and it started playing and died again but didnt shut down.. when i put a new batterie in it to turn it on, thats what happened
Jul 08, 2008 | Audio Players & Recorders
"DCER" flashing....
That is a DC error.
What happened and why?
amp IC is fried, probably from overheating playing at very loud level. Maybe from a speaker going bad, maybe just random part failure
Is this fixable?
Yes
How do i fix it?
You must get the replacement part, take the radio apart, remove the solder from the amp ic, put new IC in and resolder connections. Put radio back together without forgetting anything you took apart. Also need to make sure the soldering is good, no solder bridges or anything like that (you wouldn't want to blow it up again right after replacing it)
How do i prevent this from happening again?
If it was caused by playing too loud for too long, don't turn volume up to point of hearning any distortion, that is clipping in the amp you hear and is very ******* amplifier ic.
If it happened from a speaker going bad you must replace the bad speaker.
If it was a random part failure there is not much you can do, you had some bad luck, thats all.
If you do not know how to remove solder and to solder very good, it is reccomended that you take it in for service, but it may not be worth it since this unit is not very exspensive. A shop may charge as much as $100 for this repair. part alone is about $30 or $40.
If you want to know the part number please reply and I will look it up for you, or you can get the generic number off the ic itself.
Jun 16, 2008 | Kenwood KDC-135 CD Player
Turning off
upgrade to the latest firmware
http://us.creative.com/support/downloads/
Jan 08, 2008 | Creative Labs Zen Micro MP3 Player
Tv shuts down
something isnt properly grounded, I would suggest trying it on another tv and see if the same thing happens there.
Nov 06, 2007 | Microsoft Xbox 360 Console
Left connected when shutdown
This happens to me every other time I connect to charge the battery. I remove the screws on the back and remove and reinstall the battery then back to normal but still without a full charge.
Apr 12, 2007 | SanDisk Sansa e260 MP3 Player
Sharp LC-32SB24U 32 in. LCD TV Logo
76 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
