Question about Casio Exilim Zoom EX-Z80 Digital Camera
My lense has stuck out and wont come in again, like it should wen the power is off, the camera is otherwise in perfect condition after 18 months never dropped etc, not a scratch on it, i dont want to buy a new one can this be fixed...??? please.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 59 Answers
The len's on these are very suseptable to any dirt, dust, sand, and grit, one little grain in the gears and stuck, I just cleaned two, one was OK, the other was beyond repair, it can be just dust from tossing it in a purse or pocket, it gets in between the case and lens, use a dust proof bag or case, the ones that come with them are open and terrible, toss up, what costs more, having it repaired or buy new, or buy different sealed type, which they are coming out with, I heard of a life-proof camera, sounds like what we need. Or upgrade to a higher end camera, they are better, Hope this helps.
Posted on Apr 27, 2010
Testimonial: "Thank you for reply"
Please tell me the best lens and flash for D3100 i m not a proffessional photographer and i rarely go to see wild animals in forest. I want to click family photographs and natural beauty
hi there,
i used d3100 a few months ago,
for your information this camera only support autofocus with built-in motor lenses
if you have interest on wildlife, you should use tele-lens whose focal length above 200mm
if Nikon lenses cost you too much, you can choose other lenses from Tamron, Tokina, or Sigma
for family photograph, the kit lens is able to do this (18 - 55mm),
for natural beauty, i myself use nikkor 50mm/f 1,8 which has great power in low light condition
hope this will help
Jan 12, 2011 | Nikon D3000 Digital Camera
This Tamron used with my Canon 1000D gives since 3 months errorcode 01 (communicationfailure between lens and body). When "off" and "on" can take one picture, then errorcode 01...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 05, 2011 | Tamron 18-200mm f/3.5-6.3 for Nikon
Auto focus stopped working
Try cleaning the contacts on the camera and the lens, this is what usually prevents AF from working correctly.
Jul 26, 2010 | Tamron 18-250mm F/3.5-6.3 AF Di-II LD...
My nikon D40 wont auto focus or manual focus it has never been dropped and was perfect on last shoot what could be wrong?
maybe you kept it in a place with high humidity and the lenses have condense between . try to keep it in a warm (warmer than usual) and dry place for a few minutes and try again
Oct 28, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My camera lense is stuck and my camera wont turn on
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Jul 28, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Lensis not coming out
If you turn it on in photo review mode the lense will not open so turn it on in photo capture mode or if dirt gets caught in the lense it would jamm it shut so try to clean it, or if the lense is dented it would jamm, or if at one time the lense tried to open indide a case or in a position where the lense was blocked the motor mioght have burned out or the gear that pushes the lense out might have broken, in the case of the last three answers then a specialist might be able to fix it , or you might need a new camera, (i reccomend a fujifilm)
Jul 23, 2009 | Kodak Easyshare C813 Digital Camera
Camera wont let lense come out
notify SAMSUNG of your problem should have warranty
Nov 18, 2017 | Samsung TL34HD / NV100HD Digital Camera
Low battery display
i had a similar problem...my lense woudnt go back in either, but it kept saying low battery and bleeping. I realised that my lense was stuck skwint, and that was what was causing the problem, once i straigtend up my lense it folded bak into the camera and worked fine wen i turned my camera on :D
May 06, 2008 | Samsung Digimax D53 Digital Camera
....the lense wont go back into the camra.
This could be your problem. I haven't worked on your specific model camera however the idea and construction has been basically the same in all the cameras that I've opened and fixed. Inside the lens assembly, right behind the front optic there are two magnets that are opposite each other. These magnets are there to close the lens cover when it detracts. A common problem with these small compact cameras are that they are dropped or subject to some kind of impact and the magnets come loose (there actually put in with a cheap little snap to save money) and the lens can not retract. The camera stops functioning because the lens can't find it home position, thus your left with a very expensive paper weight. So what's the solution? Well, if your handy you could get yourself a pt. 0 philips and open the camera. Be careful of the capacitor (it looks like a battery), it can remain charged for several months and depending on the condition could hurt you bad. Once the cover is removed you can remove the lens assembly and further disassemble it. Make sure that you mark with a pen the position of the lens because you will have to reassemble it exactly or the camera won't focus. once you pull the CCD pickup from the back of the lens you will see the out of place magnet. Put the magnet back, add a very small amount of Crazy Glue to it, and reassemble in reverse order. Your camera should be as good as new. Good luck!
Oct 04, 2007 | Olympus Stylus 760 Digital Camera
Casio Exilim Zoom EX-Z80 Digital Camera Logo
177 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
