Question about Lenovo ThinkPad SL400 Notebook
Volume up/down buttons don't work unless I reboot.
The volume up/down buttons don't work and just make the sound stutter unless I do a reboot. After a reboot they only work for a little while.
  • 942 Answers
Hi visionair , try to shut down the pc. Then remove all cables from the computer. If it is a laptop, remove the battery, if it is a desktop, proceed to the next step.
Push and hold the power button for 5 seconds. Then plug back all the cables (including battery if it is a laptop) and turn on the pc.
Check the volume up/down buttons if it works.
Hope this helps....
Posted on May 08, 2010
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
Tip
With article and troubleshooting guide solution for Android Hard reset way
  • Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press then release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
6. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
7. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
8. Here is a common method used to hard reset an LG Android smartphone. So if you need to hard reset an LG Optimus this is the hard reset key combination to try first.
After the LG phone has been powered off, press and hold the Volume Down button. While holding the Volume Down button, press and hold the Home button. While holding both the Volume Down button and Home button, press and hold the Power button.
Continue holding these three keys down simultaneously until the LG logo appears.
Once the LG Logo appears release all of the keys. This will complete the reset on many LG phones; you will be given the option to "Select your language" and can proceed with setting up your device as if you were setting up the phone for the first time.
If however, you are taken to a fastboot screen or a screen with additional options then use the Volume Down key to scroll to and highlight the wipe data/factory reset option and then press the Menu key to make the selection.
The phone might give you a confirmation screen in which you can use the Volume Down key to scroll to and highlight Yes -- delete all user data and then press the Menu key to make the selection.
If you get an option to reboot system now then select that option with the Menu key. The phone will reboot, which can take a couple of minutes, and the hard reset will be complete.
Now you know how to hard reset an Android Smartphone and the next time your touch screen stops responding, your phone freezes, your phones power cycling, you forget your password, or pretty much any reason you wouldn't be able to perform a reset through the settings, you'll be set.
If I have forgotten any key combos that you know of, leave the method in the comments below so that I can add it to the list. Don't forget to check out some of our many other popular posts and don't forget to power your phone off every couple of days and watch what applications you choose to download onto your device that way you can keep your phone healthy and efficient. Hope you enjoyed the article, have a fantastic day, and enjoy your phone.
Thanks for checking out this Solution. Phonetolls.blogspot.com contents provide include dozens of cell phone artical additional, pictures, with hardware and software troubleshooting guides for you. Support us like and connect with this blogger for latest newsletter please follow me. By Admin shahid abbas
Phonetolls
on Jun 24, 2015 | Cell Phones
My HTC First is stuck on safe mode and when I try to reboot it the power button or volume down button doesn't work but the volume up button works fine and at the top its say "*** LOCKED***". How do
To get out of safe mode all you have to do is reboot the device, nothing else. The phone should be bale to work fine but without any third party applications.
If what you see on the display is just a bunch of letters, then you are in the recovery section. I'm not sure, but I think that once you highlight a line just tap the Home icon to activate. Make sure that "Reboot Device" is highlighted to reboot the phone in normal mode.
Dec 12, 2014 | HTC Cell Phones
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
How to reboot cherry mobile spark tv?
Here`s how to hard reset you Spark Tv
1. Turn off the your Cherry mobile Spark
2. Press power button, Volume down and home button at the same time.
3, Wait for a Spark TV logo then release power buttons and continue holding Volume down and Home.
4. Scroll down and select wipe data then press home button
5. Select reboot and your phone will be unlock but all files in the internal storage will be deleted.
or try this
SPARK TV cherry mobile HARD RESET too many patterns attempt solution
POWER ON + VOLUME DOWN BUTTON press together in 20 seconds or until the Android system recovery <3e> appeared
Press volume down to wipe data/factory reset then press power on
Press volume down Yes -- delete all user data then press power on
Press power on to reboot system now
After reboot HARD RESET was done
May 20, 2014 | Nokia E Cell Phones
Kurio 4s need help
You can perform a reboot by holding the volume + button and power button at the same time. Release the power button after 5 seconds but keep holding the volume + button until a screen appears with options. Press the power button to select reboot. Next you will have to scroll down using the Volume + button again to highlight yes and press the power button to select. If the reboot does not work, you many have to perform a factory reset using the same steps except you have to use the volume + button to scroll down to the factory reset option. Hope this helps.
Feb 26, 2014 | Tablets & eReaders
Won't reboot
different keys have hard reset in android tablet PC's
you should try using any of these methods
volume down + home button + power button
volume down + power button
volume up + menu + power button
volume up + power button
volume up + cam +power
volume up + lock button + power
If the above does not help you in making a hard reset then you should share your android tablet's full details here
tablet brand
model
good quality image
screen size etc ( 7or 8 or 10 ) so we can help
Thanks
Feb 03, 2014 | Le Pan II 9.7" Tablet PC
Hard reset motorola atrix dual core smartphone
  1. Power off the phone.
    NOTE: If unable to power off, remove and reinsert the battery.
  2. Press and hold the Volume Up + Volume Down and the Power button.
  3. The screen displays Boot Mode Selection Menu; press volume down key to cycle through choices until Android Recovery is viewed. Press the Volume Up key to boot in this mode.
  4. Wait for the triangle ! / Android screen to display, then proceed to step 5.
  5. Press both Volume up and Volume down key simultaneously. A recovery menu displays.
  6. Tap on Volume Down key until Wipe data/factory reset is highlighted, and tap the Power button.
  7. Another confirmation screen displays. Tap the Volume Down key until Yes displays, then tap the Power button.
  8. After user data is cleared, the reboot system now option is highlighted by default. Tap the Power button.
  9. The phone reboots to the initial setup screen.
Wireless
Nov 23, 2013 | Motorola Mobility Nice Atrix 2 4g Hd At&t...
Trying to unlock google password and it want let me get out of it
leave the phone on take the battery out this should reboot the phone
Oct 07, 2011 | HTC EVO 4G Smartphone
How to reset my samsung galaxy
METHOD TO RESET GALAXY
STEP 1: Switch off your phone, remove its battery, and then place it back.
STEP 2: Now, hold the Volume Down button and Power button. And then release the Power button while still holding the Volume Down button.
STEP 3: Now you will get a list of options to choose from. Which would be like:
  • Fastbook
  • Recovery
  • Clear Storage
  • Simlock
STEP 4: There, choose the Clear Storage option.
NOTE: Use Volume UP and Volume Down keys for navigation and Power or Home button for selection.
STEP 5: Now confirm by pressing Volume Up button (YES) or Volume Down (NO).
That is it! Now, you Galaxy S will reboot and you will find that you have reset your Galaxy S to factory settings.
Jun 30, 2011 | Samsung Galaxy S GTI9000 Smartphone
Lenovo ThinkPad SL400 Notebook Logo
429 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
