Question about Canon S520 InkJet Photo Printer
Getting a 5100 error message printer head
Getting a 5100 error message printer head alignment problem
tried relignment acouple times
  • 4,041 Answers
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 27, 2010
Canon pixma mx432 printer error 5100
I have a Canon mx432 that was new, but gave me a 5100 message that I couldn't clear. I cleaned the transparent belt that guides the print cartridges, and now it works great. I spent hours on it until I cleaned that strip - - nothing else worked
Sep 12, 2012 | Canon Pixma MX420 All-In-One Printer
Check printer 5100 error message.
error code 5100 means print head temperature rise error. In other word the print head is overheated. First,turn off your printer for some minutes (it recommended to take about 30 secs or more) and let it's cooled down. Turn on again. If the problem still persist,try to check whether the print head is good or not by comparing with another print head. Be carefully,sometimes this problem is caused by short circuitry inside the print head.
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Service error 5100
Solution 1:
Solution 2:
Dec 17, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Canon Pixma MP130 error 5100
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Error message 5100 on Canon i560 printer
Hi You can Try
Same old errors
Error Code 5100
Solution 1:
Solution 2:
Oct 27, 2008 | Canon BubbleJet i560 InkJet Printer
CANON ip 4300 - 5100 error & prints skew onto DVD
I had this eror. It was caused by indexing error left to right.Would print some then cancel after starting to make clunking and left to right error gets to large.(white edge up the side of full page print).
There is a toothed print head carriage drive belt and a clear indexing strip above the heavily white greased bar behind print head carriage.
If this clear indexing strip gets grease or anything else on it the print head cannot index.
With print head at full right position,power off, I carefully wiped the clear strip by pinching between clean dry fingers and wiping up and down the strip a few times,maybe use cotton wool buds and IPA or methalated spirit if you can't get your fingers in there without breaking the strip. then with power on print head in change cartridge position,push carriage to far left and wipe right side of clear strip.I pushed carriage full left to right a few times,Then ran print head alignment.Fixed without taking apart.
Jun 23, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Ink error
did you run a head cleaning and alignment?
http://tinyurl.com/6qcpgy
Jun 06, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Correctly fitting ink cartridge/pring head relign?
Here is a link for the user's manual. It will tell you how to correctly insert the cartridges and do a print head alignment.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Just look on the page for the user guide. If this is what you were looking for please rate a big 4 fix ya. Thanks. Need more help? Just post a comment and I'll be back to help you out.
Mar 25, 2008 | Canon PIXMA MP160 All-In-One Printer
Canon printer i560 error 5100
Hi You can Try
This been here long time
Error Code 5100
Solution 1:
Solution 2:
Oct 29, 2007 | Canon MultiPASS F60 All-In-One InkJet...
Error 5100 - what does this mean?
Hi Luza, A 5100 error is a carriage problem. That means it could be the code strip, carriage assembly or logic board. First make sure nothing is keeping the print head from moving all the way across the printer. If the smallest thing blocks the head from going all the way across it will generate this error. You'll want to look hard for ANY obstructions anywhere. Throughly check the gears and rollers for obstructions too. Second the code strip (or timing strip) is the 1/4 inch plastic strip that runs across the printer and through the head carriage. It's got supports on both sides. If becomes dislodged it will generate this error. (it's got a tesnsion spring on one end) I have a feeling that is your problem. That somehow when you replaced the cartridges you may have dislodged the code strip. That might account for not being able to correctly align the print head too. Make sure it's straight, level and secure. Also make sure it's not dirty. Grease or dirt on the code strip can generate a 5100 error. You can clean it with a damp cloth (water) but be careful if your going to remove it from it's anchors. You can try cleaning the steele bar that the carriage runs across as well, but you'll have to lube it back up with a cloth dampened with some 3 in 1 oil or a light machine oil. If none of that works and your ABSOLUTLY SURE there is nothing in there blocking the printer then it must be either the carriage assembly or logic board. If either is the problem you're going to need service on the unit or a new printer. I hope this helps. Please let me know how you make out, Dude
Nov 15, 2006 | Canon Pixma iP6600D InkJet Photo Printer
Canon S520 InkJet Photo Printer Logo
101 people viewed this question
old marine
old marine
