Philips 50pfp5332d/37 blown main fuse, Going to get a new one, If it blows out again, what should i check for next? Plz looking for someone that has worked on this set b4,
  • Matthew Albert
    Matthew Albert Apr 27, 2010
    main fuse on power board,, new fuse fixed,,
    is this a temp fix?
  • 4,889 Answers
Where exactly is the location of the fuse? The power board? Also which fuse is it? The main fuse or the one near the IC regulators and protector?
Posted on Apr 27, 2010
  • eagle338
    eagle338 Apr 28, 2010
    The main fuse blowing is an indication that there are power surges in your area. Use a surge protector or voltage stabilizer to solve this problem or both if the problem is severe.
Philips TV, Model Number 50PFP5332D/37, the screen starts out all black, but then slowly the black starts to dissipate and the picture starts to come through. However, the picture is all gray & fu
You more than likely heard a pop noise when this failed, the infamous pop of death when the Y sustain module fails. First check the various fuses located on the Y and X sustain modules. If a fuse is open you have lost the large IC on either PC board. These boards are located left side 3 module and far right side module with ribbon cables attaching to display panel. This can be a complicated repair due to one of the buffer modules failing, The Y sustain will be identifies by Samsung drawing number LJ92-01200A, The Buffers are LJ-92-01202A, LJ92-01203A. This is most likely a job for a pro because 1 of or all 3 modules can be at fault. Some services on e-bay for these modules offer rebuilding the Y-main module and also testing the Y-buffers. If you want to DIY this TV this would be the best Idea, send three boards to a rebuilder on E-bay.
Mar 05, 2013 | Philips 50PFP5332D 50 in. Plasma...
Panasonic 3 blink error 50pfp5332D/37
First off, 50PFP5332 is not Panasonic, but Philips.
Second, what I would do is this: open the TV by taking off the back cover (that's lots of screws to unscrew) and try to powering it on again.
There is a little green LED on a small board sitting at the lower right corner of the power board (see image in the listing below).
Look at that light when the TV comes on and see if it starts blinking or if it stays solid.
if it blinks you *likely* (not surely) have a problem with the power board.
if not then you can start looking elsewhere and the Y-Main board will be my first candidate...in fact you can also try disconnecting the Y-Main board from the power to see if that will make difference in the startup behavior of the TV.
That's as much time as I can allocate you at no cost.
For more use www.coppelltvrepair.com/diagnose .
Oh, and the listing for the power board repair:
http://www.ebay.com/itm/LJ92-01511A-996510019427-POWER-BOARD-PHILIPS-50PFP5332D-REPAIR-SERVICE-/110889089101
Sep 25, 2012 | Philips 50PFP5332D 50 in. Plasma...
Philips 50pfp5332d/37 won't power on...led light blinks 4 slow, 6 fast...i can not find error code 46 anywhere
Error 46
Description Pacific 3
Detected by VIPER
Device T6TF4HFG
Error/ Prot E
These info are for qualified service technicians.
Sep 09, 2012 | Philips 50PFP5332D 50 in. Plasma...
Philips 50'' Plasma TV model 50pfp5332D/37 GREEN BLINKING ON LOGIC BOARD
Main digital processor IC on the board has damaged. It is not a replaceable part, as normal soldering techniques cannot be applied to de-solder it out from the board, or to solder a new one in place. Card base replacement should be done.
Aug 14, 2012 | Philips 50PFP5332D 50 in. Plasma...
No sound opened component two blown fuses
Fuses blow when there's an overload. This is often caused by faulty speaker wiring. But the main problem you have will be that the main power amp will have failed. You will find this on a big heat sink. It could be transistors, or a power amp IC, picture below of what that could look like.
Jun 30, 2012 | Philips MCM704D/37 Shelf System
We were watching tv last night and it the picture just turned off. the machine was on but no picture. i turned off the tv and tried again this am. no picture.
You either need this part (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ92-01401-Buffer-Board-/150501144120?pt=LH_DefaultDomain_0&hash=item230a913638) or this one depending on your dead screen issue (http://cgi.ebay.com/Philips-50PFP5332D-37-LJ41-04216A-X-SUS-XSUS-Board-/170550290208?pt=LH_DefaultDomain_0&hash=item27b596e720)
Oct 20, 2010 | Philips 50PFP5332D 50 in. Plasma...
How many Main Boards are in the Philips 50'' Plasma TV model 50pfp5332D/37?
has only one main board
has many sub bords supporting tat main board
Mar 08, 2009 | Philips 50PFP5332D 50 in. Plasma...
Blows Fuses
Hi
They have so many reasons why blown fuses in TV... all you have to do is to check the shorted semiconductor like regulator and drivers..
Thanks!
Feb 24, 2009 | Philips 27PT5441 27" TV
Blown fuse 1.25amp Board pos. 1452
The main fuse should be a 4 amp fuse not a 1.25 amp.
Jan 26, 2007 | Philips 32PT6441/37 32" TV
Televison & Video Logo
418 people viewed this question
Top Televison & Video Experts
Electro Med Services...
