Question about LG WD-3274RHD Front Load Washer / Dryer
Hello, My LG WD-3274RHD has a puddle inside the main door gasket. It appears to have a drain hole at the bottom but I would guess it is clogged. Any heroes with a solution out there? Many Thanks, William
MNTECH
  • 1543 Answers
SOURCE: door seal wont drain
I would suggest using a blunt object to clear the drainage holes in the rubber seal. I'd advise against removing the seal for this problem. LG has special pliers to remove the spring loaded wire from around the front of the door seal and another for the larger size one where the rubber seal attaches to the outer drum. The second one is much harder to reattach, even somewhat difficult with the washer's front off if you do not have the special pliers.
Posted on Aug 27, 2008
  • 566 Answers
SOURCE: Retro-fit drain hose
hi not seen one of these retro types but having always wiped the seal and door after use as recommended with clean damp cloth prevents seal deteriation i would have thought this drain?on retro type that drains accumulation of any water from seal would be draining inside the outer drum and thro to drain into pump? seems odd?
Posted on Oct 22, 2008
SOURCE: How to replace door gasket on LG WM0642HW Washer?
I also had a door gasket tear that caused water to spit out all over the floor so I had to replace it. It's a fairly simple job in theory, you can even find LG repair manuals online. The front panel comes off easy and removing the spring and wire clamps from the gasket is fairly simple. Getting the gasket back on is a different story. Seating the gasket is a bit tricky but I found that some lubrication helped greatly. Don't use oil based lube though because it could soften the gasket. I opted for a water based lube in the form of KY jelly (***insert crude joke here***) The drum side wire clamp was a bit of a challenge. My model had a hook on one end of the wire so that it came apart when removed. I think this made it much easier. Some models don't have the hook so you would need a tool that could stretch the spring. Something like a reverse pliers. Even with the hook, it was tricky. I found that jamming something around the gasket to hold the wire in place was helpful. I ended up using some vice-grips and needle nose pliers and all the strength I had to get it hooked. In fact, to sum up, the secret is to get enough force to stretch the spring. Once you figure out how to do that it's easy.
Posted on Oct 04, 2009
SOURCE: My Lg WD-3274RHD after a load is complete It fills
I have same problem with my washer/dryer combo.It took me quite some time to figure out what is going on.Did all electrical checks ,everything was fine and worst thing it was intermittent thing ,it would do it 8 out of 10 times. Found cold water inlet valve assembly to be faulty (mechanical problem with middle valve) . Second time in 6 years ,other than that I'm very happy with that combo.Problem now is to get new valve, because it is not available anymore from LG, so I'm digging through internet to see if anybody has it somewhere. Good luck
Posted on Jun 06, 2010
MNTECH
  • 1543 Answers
SOURCE: the door gasket on my
I use nylon cable (zip) ties to clean them. (Not sharp, so no danger of poking holes in the gasket) You may want to run a washer cleaner through the machine occasionally, such as Affresh or Washer Magic, or one made by Tide or Clorox.
Posted on Jul 24, 2011
Water standing on floor of drivers side.
Could be the drain holes on the bottom of the door are clogged. Check to see if they are clogged and clear them. Also check for drain holes or slots on bottom of fame under and around the door. It's probably not the door gasket, unless you are seeing wetness on the inside of the door.
Mar 21, 2014 | Chevrolet Blazer Cars & Trucks
Please Help! My LG WD-3274RHD has the error code "dE" after replacing assembly door switch?
dE for LG does the spring of latch hook actuate? no> fix door latch Yes> is there clicking sound once or twice when the start/pause button is pressed to start the cycle? No> check door switch and main PWB Assemblyhope that helps..
OE is Drain Error.
Sep 02, 2012 | LG WD-3274RHD Front Load Washer / Dryer
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
Leaking inside of fridge - puddling below vegetable bins - is that the defrost cycle drain clogged up
In the rear of the fridge is a access panel. Remove it and check that the tray on top of compressor has water in it. If no, which I'm guessing it doesn't, then the drain tube is plugged. I like to cut the bottoms off for better drainage or at least make the hole on bottom a little bigger
Apr 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My washer/dryer is leaking water as the drum is filling. Does not matter if it is hot, cold etc. I have already cleaned the filter..... HElp!!!!!
your tub fill tube hose that goes from the bottom of the wash tub to the load size control on the control panel may have a hole in it, its plastic
Aug 24, 2009 | LG WD-3274RHD Front Load Washer / Dryer
LG front load washer leaks from door gasket
This is best left for a proffessional to repair
Affordable Appliance Repair
LAke Forest, CA. 92630
Aug 21, 2009 | LG WD-3274RHD Front Load Washer / Dryer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Oct 22, 2008 | LG WD-3274RHD Front Load Washer / Dryer
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
LE Error??
your handbook should say what "fe" (a fault code) is. it may be not draining. have you checked the filter? on many machines the door can not be opened if water is still inside. try putting the drain hose at floor level into a bucket. otherwise undo the filter and let the water out that way - you may have water everywhere!!
Mar 19, 2007 | LG WD-3274RHD Front Load Washer / Dryer
LG WD-3274RHD Front Load Washer / Dryer Logo
27 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
